September 24, 2026, 06:06:14 am
i need help for my EMPI steering wood wheel
Topic: i need help for my EMPI steering wood wheel (Read 7130 times)
cox64
cal look addict
January 13, 2010, 15:23:14 pm »
hello everybody,
it is not vernished, , it stayed too long under the California sun
I'd like to restore my EMPI steering wood wheel . but I do not know what to use
What should I use to restored this one ? (lacquer or vernished ) and what is the kind of wood ?
thanks in advance for your help
phil
the cal look is not a style for me....it's my life ;o)
Speed-Randy
Re: i need help for my EMPI steering wood wheel
January 13, 2010, 16:26:46 pm »
What is wrong with it? Cracks in wood? Just peeling laquer?
www.vdubspeedshack.com
cox64
cal look addict
January 13, 2010, 18:33:52 pm »
there is no crack in the wood .. the laquer or the varnished is just delete
i have send for you a mail with pictures
January 13, 2010, 18:49:45 pm »
Strip it, Sand with 220, Then a couple coats of sanding sealer,Sand 320, then spray with your clear of choice
cox64
cal look addict
January 13, 2010, 20:11:16 pm »
thank 's danny , but I do not know the product "coats of sanding sealer" .. Do you think I could find this product in France?
Solexine
January 13, 2010, 21:02:19 pm »
Bouche pores
cox64
cal look addict
January 13, 2010, 21:28:46 pm »
Quote from: Solexine on January 13, 2010, 21:02:19 pm
Bouche pores
thank you
January 13, 2010, 21:39:29 pm »
Just buy a new one from Flat 4, and give me your old one that worth nothing now.
Speed-Randy
January 14, 2010, 05:41:59 am »
I use kleen strip paint stripper( it won't hurt the wood), scrape it with plastic putty knife, DO NOT USE A METAL knife, it will gouge the wood. Then mask the metal, use a 180-220 flapper sanding disc to get the majority of stain and left over clear. Then I hand sand with 220 to clean up any sand scratches. Remove masking tape and stain wheel to proper color, then clean the stain off metal it will wipe right off, mask the metal again sprat it with sanding sealer let dry, hit it with fine steel wool, then spray it with automotive clear wit about 6 coats to get a nice finish. Install and enjoy
John Rayburn
January 14, 2010, 06:22:02 am »
Don't use steel wool, it will rust under the clear.
I also park at Nick's.
January 14, 2010, 06:24:43 am »
Rayburn's right, but DO use bronze wool. It doesn't rust and does the same thing as steel wool. Very effective stuff.
cox64
cal look addict
January 14, 2010, 17:57:57 pm »
thank you everybody for your help
stealth67vw
January 15, 2010, 03:31:37 am »
The wheels came in Mahogany and Rosewood.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
