September 23, 2026, 20:18:05 pm
| | |-+  IDA stacks getting loose
Author Topic: IDA stacks getting loose  (Read 4285 times)
Felix/DFL
« on: January 14, 2010, 23:04:37 pm »
Hi,
I have a problem with the orig. IDA stacks (spanish IDA`s)
As said the stacks (2-3 of them) are getting loose and can be turned by hand and rattle. I have bended both of the outer edges of the clamps down a bit which solved the problem. But only temporarly... They came loose again.
It seems that the stacks are to deep into the gasser body so that the clamps don`t really press the stack "ring".
Have you had simular problems and how did you solve them?
Greetings,
Felix
stealth67vw
« Reply #1 on: January 15, 2010, 03:24:03 am »
Art Thraen (ACE) sells thicker tabs that don't bend.
http://www.aircooledengineering.com/carbparts.html/
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
« Reply #2 on: January 15, 2010, 08:51:32 am »
Try an Italian stack, maybe the lip is wider, I noticed that also with my Spainish set. I have a Italian set of IDA's, I'll pull the stacks and take some measurements.
Ted
Tobi/DFL
« Reply #3 on: January 15, 2010, 09:59:12 am »
Hi,
I have the same problem with my italian IDAs. I guess it´s caused after swapping the chokes which may be a littler shorter than stock ones. I often use a short (1cm) wire beneath the tabs to get the stacks tight which usually solves the problem.
Bye,
Tobi
DOUG BERG
« Reply #4 on: January 15, 2010, 18:00:46 pm »
        IF THE ENTIRE MASS HAS BEEN   "PROPERLY BALANCED",,,
        I'D SUGGEST    "A COMPRESSION CHECK",,,
        CAUSE "NO MATTER HOW WELL" ITS BALANCED
        A "LOW HOLE" WILL "RATTLE IT TO DEATH"!!!
        DOUG....
                                                           OR  "AFTER MARKET RUNOUT"     ON A "BAD COPY OF OUR PULLEY'S" !!!!
Felix/DFL
« Reply #5 on: January 17, 2010, 00:33:03 am »
Thank`s for the advives! I will see what works.
