August 12, 2026, 07:41:05 am
Non leaking pushrod tubes?!?
Topic: Non leaking pushrod tubes?!? (Read 23282 times)
WheelieNelson
April 11, 2006, 08:34:23 am »
My pushrod tubes are leaking mad! and i purchased new ones form scat.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C15%2D20175
Is this a good choice? If not... whats HOT?
[img="http://ligan.gdi.no/images/logo-JessheimLigan-100x100m.gif"]
Frank LUX
Back...Soon...hopefully!!!
Re: Non leaking pushrod tubes?!?
April 11, 2006, 10:11:19 am »
Quote from: WheelieNelson on April 11, 2006, 08:34:23 am
Never tried Aftermarket Tubes...
I'm using OG VW "CT" Tubes on my engine, but you have to Modify you Heads to accept them...
Frank
Karmann
April 11, 2006, 13:58:48 pm »
There's only one aftermarket PR tube that works properly and that is JayCee. I little bit more expensive but definatly worth it. Beware of fakes though. Buy from the source or from an authorized dealer like Vee Dub Parts Unlimited (
www.vwparts.net
Roman
April 11, 2006, 16:41:43 pm »
CB:s tubes works well too.
http://www.cbperformance.com/catalog.asp?ProductID=123
Petter Carlberg
April 11, 2006, 17:23:14 pm »
I have used the Scat-tubes on my last two engines. I like them a lot!!
Tim C
April 11, 2006, 17:24:56 pm »
I'm about to have a set of the JayCee tubes put on my engine - all I have heard is good things about them.
JG54 Greenhearts
WheelieNelson
April 11, 2006, 19:50:37 pm »
Quote from: Petter Carlberg on April 11, 2006, 17:23:14 pm
So they did not leak..?
The last set i bougth i had to pump full of silicone, but tht where still leaking..
http://www.mooreparts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=AC109353&Category_Code=
Keep away from this crap!
Ulf
Martin Greaves
10.88@128.58
April 11, 2006, 19:58:10 pm »
The Jaycee tubes are dam good you can get them from here.
https://www.vwparts.net/Merchant2/merchant.mvc?Screen=PROD&Product_Code=JCTUBES&Category_Code=JAYCEE
WheelieNelson
April 11, 2006, 20:15:20 pm »
Ok. I will try the jaycee tubes if the ones from scat dont work out
bugkeeper
oldskool n numetal
April 11, 2006, 21:10:52 pm »
I used Scat pushrod tubes on 4 engines. On two engines I used them to replace leaky original tubes. The other 2 engines I built from scratch with Scat big mouth spring loaded push rod tubes. I am very happy with them. Just make sure to clean the mating surface perfectly and I mean
perfectly
. On one engine I used Dow Corning silicone grease to seal them instead of Loctite 574 what I normally use. It worked without any problem what so ever. Again make sure the mating surface is thoroughly clean, align the tubes well and make sure to seat it properly.
Peace Dom
WheelieNelson
April 11, 2006, 21:58:46 pm »
Quote from: fathing on April 11, 2006, 21:10:52 pm
perfectly
Peace Dom
Thank you Dom! I will try to replace the old ones i few days. And it now seems they willl work out fine
