August 14, 2026, 07:03:00 am
| | |-+  Engine Kit
Author Topic: Engine Kit  (Read 9324 times)
fredy66
« on: January 20, 2010, 02:54:47 am »
hei is this any good ??
i love some power
http://www.thesamba.com/vw/classifieds/detail.php?id=863886
that's 454 inn €  Grin
or is this a better start ??
http://www.thesamba.com/vw/classifieds/detail.php?id=558089
i'm not made of money so cant afford to do is the wrong Way
thanks
arabia slugs
« Reply #1 on: January 20, 2010, 12:18:47 pm »
I would buy from somebody well known,
i got screwed over big time: payd for parts, but never sent
« Reply #2 on: January 20, 2010, 14:48:26 pm »
are you ready to cash out for good carbs, exhaust and other parts you´ll need to comply with a stroker? I had a very good luck with Brothers Machine company for my 2276 engine build.
fredy66
« Reply #3 on: January 20, 2010, 16:32:10 pm »
yes i do now i need carbs and mm
the plan was that i start to collect some parts now when my car is getting there.
an bid the new Eugen ower next winter.
my last bug had a 1835 40 dello but i want something bigger now.
strite  engine that can take me to scc end back
150 to 170 hp
arabia slugs
fredy66
« Reply #4 on: January 20, 2010, 16:49:32 pm »
http://www.thesamba.com/vw/classifieds/detail.php?id=713174
so this is a good company and good parts ??
time to start saving some $$$ just love the dollar now days  Roll Eyes
arabia slugs
181
« Reply #5 on: January 20, 2010, 18:16:38 pm »
They are very good in shipping overseas, they are very quick in shipping and communication and mine and others feedback to their machining is also very good.
« Reply #6 on: January 20, 2010, 20:34:11 pm »
 Lips Sealed
« Reply #7 on: January 20, 2010, 23:11:52 pm »
2 of the adverts are people I deal with and use there services,the other I dont know,my only concern with these "bargain engine kits" is there are often small problems with quality control and you may find you spend more money fixings problems than if you bought better quality parts,you may get lucky,lots of people make these products work,but not everyone who buys them.i still think its better to wait and save some more money if thats what it takes to buy parts that will work.
cheers richie,uk
181
« Reply #8 on: January 21, 2010, 00:37:17 am »
 Lips Sealed
I know that you are not a fan of Brother´s work maybe you just got  a bad luck but everything I ordered was exactly by order, clean and in specs. I re-measured everything as I´m very careful about my build.
fredy66
« Reply #9 on: January 21, 2010, 04:51:37 am »
thanks lots of good info coming
arabia slugs
A-C
« Reply #10 on: January 21, 2010, 08:06:41 am »
Ask same sets Tomppa (www.aircooled.fi)  you surprised Smiley  and you get home delivery slugs heaven Cheesy
fredy66
« Reply #11 on: January 21, 2010, 08:22:15 am »
that a idea. and as we slugs are some Lacy bastards home delivery is a good thing
and ho are you ?? Mr A-c
arabia slugs
fredy66
« Reply #12 on: January 21, 2010, 08:31:26 am »
double post  Roll Eyes
« Last Edit: January 21, 2010, 08:33:00 am by fredy66 » Logged
arabia slugs
A-C
« Reply #13 on: January 21, 2010, 08:38:35 am »
Fredy
You have PM
fredy66
« Reply #14 on: January 26, 2010, 14:53:51 pm »
have been looking at this engine forget the names think i mail aircoled.fi
what do you think i have heads 40x37
Forged 82mm Crank from DRD Racing; std VW Journals
- 5.4” CB Performance I-Beam Rods w/ 3/8” arp bolts VW Journals
- 94mm Cima/Mahle Forged Stroker Pistons (with Total Seal oil Rings)
- Race balanced by Jason @ VW paradise
- Teflon piston buttons
- Engle 120 Cam (0.397 lift @ the cam, 294° on 108/106 lobe centers)
- 1.25 Ratio Forged Rockers on solid shafts
- SLR Lifters
- Chromoly Push Rods (Manton cut to length)
- flywheel & clutch balanced by VW Paradise
Heads are CB 044 Performance hand ported set up by DRD Racing Heads to L5
a. Intakes match ported to heads
b. 40mm x 35mm Valves
c. Dual Hi-Rev Valve Springs adjusted for 0.500” lift
d. Combustion Chamber 56cc’s
Case is an AS41 VW Dual Port Case (std bearings)
a. Machine work done by Jason @VW Paradise
b. Clearanced for stroker crank
c. Chromoly 10mm head studs with case savers
c. Full Flow w/ 30mm oil pump and chassis mounted external oil filter
d. Deck Height Set at 0.080” (Approx. 9.2:1 Compression Ratio)
e. Oversized Chromoly Gland Nut and Washer
Doghouse oil cooler system with welded/balanced fan
Thermostat controlled auxiliary oil cooler with electric cooling fan
Claude’s Buggies low profile extended oil sump
Mallory Unilite vacuum/centrifugal advance distributor
40 Dual Dellorto Carbs w/ 34mm venturies
Kush-Loc Clutch Disk
Kennedy Stage 1 Pressure Plate
Lightened, forged 12V Flywheel
arabia slugs
