November 03, 2026, 21:51:44 pm
| | |-+  and another dual quiet pack question
Author Topic: and another dual quiet pack question  (Read 16532 times)
wolfswest
« on: January 21, 2010, 12:02:54 pm »
Hi Guys,
I just can't stop thinking of how I can improve a dual quiet pack.
I love the period correct look but I want it to perform almost as well as a phat boy style muffler if possible...
the short story:  Had a stainless steel phat boy that performed very good with my engine but LOUD, and when I say loud I really mean LOUD AS HELL.
Then I tried a bugpack dual quiet pack with a bigger flange (so the flange was even big as the phat boy flange) very quiet, not to say it almost sounded like a stocker...  but I felt that not only the noise went down but also the HP...  Undecided
I've seen that Tobi designed a DQP with bigger tubes but what about the mufflers?
My question is, before I cut my new bugpack DQP does anybody know what kind of muffler the bugpacks are?
a few examples:
wolfswest
« Reply #1 on: January 21, 2010, 12:08:07 pm »
or is it like a free flow phat boy muffler style?
example:
If it's like option 1 it should be pretty straight forward to convert the two mufflers into a free flow system.
cons: okay, more noise but still less then the stainless steel phatboy becasue the steel of the DQP is thicker and you have two mufflers.
pros: better flow and it will perform better.
Or maybe a DQP is already like option two and I have to deal with it...  Undecided
Dem
Jeff68
« Reply #2 on: January 21, 2010, 19:16:51 pm »
Since I drive my car on the street and freeway, NOISE and just being too loud in the car to speak to a passenger in the car is the reason I had A-1 build me a dual quiet pack style muffler.  Tiger told me that the dual quiet pack he built me was tested on the dyno with a 200hp engine and it didn't provide more restriction than the typical single magnaflow muffler that is commonly used. The A-1 dual quiet pack that I had built has two magnaflow mufflers on it.  I didn't know what the internal configuration of it is but i suppose I could ask him.  As per my other post, I still haven't installed it as i have some fitment issues.  I should have it done soon and I'll be interested to see if the dual quiet pack limits the performance of the engine.
« Reply #3 on: January 21, 2010, 19:24:12 pm »
hey Dem,
maybe speedshop near you have good mufflers?
thats where i bought my glasspack.
 maybe we could build a few, like Tobi did,
I would want to make something anyway
wolfswest
« Reply #4 on: January 21, 2010, 19:40:45 pm »
Jeff, that sounds good!  Please post some pictures when you've mounted the DQP.  What was the price if I may ask?  you can pb me if you don't want to put it in public.
« Last Edit: January 21, 2010, 20:00:56 pm by wolfswest » Logged
RhoadsVW
« Reply #5 on: January 21, 2010, 22:16:43 pm »
On both my green car and my street car I have Thunderbird dual mufflers. My street car has the standard system with a 2027. The green car has the 1 5/8 merge system. They are copy of the 4 tuned system and fit very good. Follow the finder line correct with chrome tips.  When dynoing the motor from my green car on Heads Up's dyno the Thunderbird made 8 horsepower more over a top competitor dual muffler. I understand that the merge system dual mufflers are not available anymore. But if you can find some I would buy them. The standard dual mufflers are still available. Dave Rhoads
Der Renwagen Fuhrers
wolfswest
« Reply #6 on: January 21, 2010, 22:24:20 pm »
nice info here Dave.  But what do you mean with a top competitor dual muffler setup?
+ how much HP did you get with the thunderbird setup in your green car?
bugnut68
« Reply #7 on: January 21, 2010, 22:53:02 pm »
Yeah, I was bummed to see that Pertronix, who is making the Thunderbird exhausts now, doesn't have mufflers available for the merged headers.
Tobi/DFL
« Reply #8 on: January 22, 2010, 10:05:19 am »
Hi Dem,
unfortunately I´m still searching for a good performing and good-looking (at least for my taste) solution. My homemade dual quiet mufflers were okay but not a great improvement over the cb merged dual quiet mufflers I used before. The main problem is that my heads are obviousely getting hotter than before. I think that the mufflers I got are of the reflexion type so this could be the problem.
My next attempt last season was to use a glasspack muffler with an 2,5" inlet/outlet bore. The throttle pedal felt like there was no restrictions anymore so I will fabricate another muffler for the next season (similar to a dual quite but with two glasspack mufflers) and will use a 1 3/4" header instead of the 1 5/8" header I used before.
The problem with finding the "right" muffler for a dual quiet in my opinion is that there are very few non-restrictive mufflers available that are longer and lower than the typical turbo-mufflers. Another factor to consider is that the inlet and/or outlet should not be centered to achieve the "correct" look.
Bye,
Tobi
wolfswest
« Reply #9 on: January 22, 2010, 10:20:50 am »
Hi Tobi,
Sad to hear that your home made DQP didn’t realise what we expected…  I loved the look and I thought that the bigger tubes were the solution.
So if I understand it correctly, your heads became hotter with the home made DQP then with the stock cb performance DQP that you used before?
I was hoping that the mufflers used with the stock DQP’s (bugpack, cb performance, …) were also reflection mufflers…  Do you know anything about this?
Thx,
Dem
« Reply #10 on: January 23, 2010, 00:46:23 am »
I have an original 15/8" Thunderbird header and dual QP's BUT mine is the later 80's type where each silencer BOLTS to a T piece which then BOLTS to the merged header - I haven't yet decided weather to cut'n'shut it so it looks more "original"/70's - I'll post some pic's soon  Smiley
bugnut68
« Reply #11 on: January 23, 2010, 01:58:44 am »
Wow, that's an oldie but goodie... the bolt together dual QPs... I was just reading an early '80s Hot VWs and saw a pic of that kit.  I was wondering why they did that?
« Reply #12 on: January 24, 2010, 23:56:19 pm »
I have NO idea dude but i tell you one thing - ITS ENOUGH HEAVY!!!
Jeff68
« Reply #13 on: January 25, 2010, 18:20:22 pm »
Sorry it took me a bit to reply.  The cost was 300 US dollars plus shipping.  225 dollars for the muffler and 75 dollars for the ceramic coating and then shipping costs.
I haven't modified the muffler installed it yet, I've got home remodeling going on and two small kids to play with as well.  Smiley  I'll get to it soon enough.....
wolfswest
« Reply #14 on: January 25, 2010, 18:28:14 pm »
Okay, Can you give me the email address I need to use for A1 mufflers?  The best contact is Tiger I've been told...?
« Reply #15 on: January 25, 2010, 18:34:44 pm »
Anyone got a pic of the rear Dave's 64 handy? His OP's Look PERFECT Smiley
« Reply #16 on: January 25, 2010, 18:43:47 pm »
what confuses me is why dual QPs work for some guys but not for others...
doesn't rick sadler run a 2387cc and doesn't he use "simple" bugpack dual QPs?
very true lee! those are nice but stick out a little too much IMO.
« Reply #17 on: January 25, 2010, 18:54:16 pm »
Cheers dude - they do come out a little further than I thought but they are still waaaaaaaaaay Cool, My Thunderbird QP's don't have chrome tips BUT that might change Wink
Dominick Luppino
« Reply #18 on: January 25, 2010, 19:27:49 pm »
Rick does use the BUGPACK dual QPs, as far as them sticking out too far, it probable depends on what manufacture header your using.
BTW they made great HP on the dyno using them.
« Last Edit: January 25, 2010, 19:29:23 pm by Dominick Luppino » Logged
Dominick Luppino
« Reply #19 on: January 25, 2010, 19:35:00 pm »
Hi Guys,
a few examples:
Looking at the picture of the cut out muffler, if you were to swap the pipe with the one in the middle with the short one on the end, that is what they would look like.
RhoadsVW
« Reply #20 on: January 25, 2010, 21:01:21 pm »
This is a picture with the Al's system on the car not the Thunderbird. The Thunderbitd mufflers are tucked in more and not sticking out as far.  Dave Rhoads
RhoadsVW
« Reply #21 on: January 25, 2010, 21:24:03 pm »
In these pictures is a photo of my car with the Thunderbird system on the car.  It's maybe 3/4 way down the page.  Dave Rhoads
http://cal-look.no/lounge/index.php/topic,9346.0.html
« Reply #22 on: January 25, 2010, 21:33:44 pm »
PERFECT JUST PERCT DUDE, Paint is looking good too  Grin (I still like the Barn look though Wink)
wolfswest
« Reply #23 on: January 25, 2010, 22:25:10 pm »
Yeah, that bothers me too!  Ricks' car performs pretty well with it, mine (with a smaller engine) doesn't perform at all with it...  Embarrassed
Dave, Dominique, thx for your input guys.
« Reply #24 on: January 26, 2010, 01:14:01 am »
you're right dave, just check some other pics i have off your car.
i know what you mean dem! it's just strange why the duals don't always work for a big engine.
Jeff68
« Reply #25 on: January 26, 2010, 14:40:13 pm »
The e-mail to use is: tigerperformance@aol.com
Yes, talk to Tiger.  He's very nice and helpful as well.
Jeff
wolfswest
« Reply #26 on: January 26, 2010, 19:08:38 pm »
Jeff
Thanks Jeff!
