September 13, 2026, 11:56:07 am
Bad Habit
Idas on Roundports?
Topic: Idas on Roundports? (Read 5057 times)
Paulus
Idas on Roundports?
January 25, 2010, 21:32:08 pm »
My Question: What will the powerband do when i use Ida's (48 mm, 40vents) on 044 Cnc roundports ?
Specs of the engine:
78,4 X 90,5 ( 2017cc )
Scat C45 camshaft
9,5 Cr
40 x 35,5 Valves ( 3 angle valve job )
1 1/2 Gene berg exhaust
Currently the engine running on 40mm Idf ( not yet driven it ) but I'm going to switch them with Ida's.
I'm asking this cause om curious about how the round ports with the Ida's will behave against mini D ports or other bigger ports.
Greets, Paul
Less is More !
Type1/DVK
Re: Idas on Roundports?
January 26, 2010, 21:57:10 pm »
What is the port size entry of the roundports?
And maybe downsize the vent's a little bit maybe...
Speak 2u soon!
DDD#8 - 14.74sec @ 1776cc - Member of: DVK ~ Der Vollgas Kreuzers -
www.ultimatevw.nl
- and racing engines
January 28, 2010, 07:22:58 am »
37 vents would work.
IDAs work on 1776s - 1914s that are setup for 40IDFs and open up the powerband.
January 28, 2010, 12:24:29 pm »
The header will limit the rpm band somewhat. But it will pull good.
FYI That cam responds very well to 1,25 rockers. And I do think your engine will be more responsive espcially from 3000 rpm & up due to the more lift on a relatively small port.
Last Edit: January 28, 2010, 12:26:08 pm by Torben Alstrup
Paulus
January 29, 2010, 22:25:57 pm »
Allright guys, thank you for the information! I made a mistake about the vents that stick in the Idas, they are 37mm instead of 40m
Less is More !
January 30, 2010, 20:39:28 pm »
Quote from: Paulus on January 29, 2010, 22:25:57 pm
so you are rich now and have more money to spend on other parts of the engine.
