September 11, 2026, 08:14:38 am
Latest Member: Bad Habit
| | |-+  "Corvair" pushrod mod and piston pin pressure oiling
Author Topic: "Corvair" pushrod mod and piston pin pressure oiling  (Read 17436 times)
181
« on: January 26, 2010, 00:32:09 am »
Did anybody tried Corvair pushrod mod? Corvair, a flat six cylinder, has a tiny hole in each hollow pushrod at the head end, right under the pushrod tip, to promote oiling of the rockers:
« Last Edit: July 21, 2011, 09:57:06 am by 181 » Logged
Martin
Cash Converter....
« Reply #1 on: January 26, 2010, 07:58:35 am »
yep
Martin
www.taylormachine.co.uk
OFF/500
« Reply #2 on: January 26, 2010, 08:08:09 am »
Interesting!
And does it work?
Best rgs
BB
181
« Reply #3 on: January 26, 2010, 12:33:39 pm »
yep
alright and how did it work? Roller or conventional rockers?
Jan
« Reply #4 on: July 21, 2011, 09:31:31 am »
and another curious question:
anybody tried piston pin pressure oiling? Small hole has to be drilled or EDMed through the length of the rod and through main bearing+piston pin bushing to deliver pressurized oil directly to the piston pin. I know Mr. Pauter offer this as extra option for his rods.
Would it be advisable to perform this mod on my H-beams?
Jan
« Reply #5 on: July 21, 2011, 09:34:22 am »
Jan, your photo of the first post has gone. Would care to elaborate as to what these mods entail?
« Last Edit: July 21, 2011, 09:51:10 am by 67-indeed/DVK » Logged
181
« Reply #6 on: July 21, 2011, 09:39:08 am »
one picture is worth 1000 words: I found the pic in my laptop.
paul_f
« Reply #7 on: July 21, 2011, 16:55:10 pm »
Does the pushrod not rotate, so that you end up with the oil spraying the wrong direction?
« Reply #8 on: July 21, 2011, 18:22:42 pm »
Jan
I was looking at a 2.0 jetta engine last weekend that came that way from the factory. If there is enough "meat" in the rod, I think it's a good idea.
Airspeed
« Reply #9 on: July 21, 2011, 21:24:08 pm »
How cool is that!
I also thought about rotation but its probably not that critical, just helping and when all 4 have it, one is bound to spray in the right direction.
Your oil pump must have the extra capacity to pump that extra.
Type1/DVK
« Reply #10 on: July 21, 2011, 22:14:11 pm »
maybe drill it directional, and it will spray more onto the casting.. nice mod though.
