September 01, 2026, 21:38:33 pm
90mm NPR pistons
Topic: 90mm NPR pistons (Read 13732 times)
90mm NPR pistons
February 10, 2007, 19:02:01 pm »
Hi,
I'm currently sending emails with a guy that says he has a set of 90mm pistons and barrels, he thinks they're mahle.
But he's sure they're not 90.5mm
So i was wondering, how can i get him to check whether they are NPR's?
AND they're slightly used, but would they still make for a nice combo? I kind of fancy the 1756cc by Frenchy:
DMS 69mm c/w crank, NPR 90mm pistons, stock rods, Engle 120 cam, 42 x 37 heads w/stainless steel manley valves, dual springs w/chromoly retainers by Steve Tims, 48 ida's on Skatrak manifolds, melling oil pump w/berg cover, Scat 2qt sump and valve covers, Berg linkage and traction bar, 010 dist, Total seal rings, 8.5:1 c/r. Full-flow system w/HP1, Phoenix 1 5/8 merged header w/super turbo muffler
DVK ~
Sander/DVK
Re: 90mm NPR pistons
February 10, 2007, 19:04:17 pm »
The Barrels are 88mm bored to 90mm, en the pistons are from a motorcylcle. I think..
But if the doesnt know anything about the pistons, what can he tell you about the engine??
Last Edit: February 10, 2007, 19:05:52 pm by Sander
February 10, 2007, 19:29:47 pm »
I think the 90's were only made by NPR. Make sure they are for stock stroke, or stroker.
February 10, 2007, 20:24:43 pm »
Got a reply off the guy, he reckons he saw Mahle engraved inside the pistons, and he said it might be a measurement error.
He's asking 150 EUR for a lightly used set, is it worth checking out? Perhaps hone the barrels and use new rings?
Keep in mind that a nice p&c set costs quite a bit more around here then they do in the states.
DVK ~
alex d
February 11, 2007, 23:38:28 pm »
I bought a new in the box set of 94s for that price
February 12, 2007, 02:23:05 am »
off a vendor in europe?
what are you using them on?
DVK ~
alex d
February 12, 2007, 10:45:59 am »
not from a vendor of course
I bought them from a guy in France who didn't build the engine he had planned, I'm building a hot 1914 for my 64
alex d
February 12, 2007, 16:42:36 pm »
BTW, I have just seen a used set of 90mm Nikasils in bugnet.de!
