October 14, 2026, 04:06:06 am
reground crank
Topic: reground crank (Read 10336 times)
reground crank
February 11, 2007, 14:09:09 pm »
hi guys,
i just got my new crank yesterday..
its a dpr and the box says:
mains: 10
rods: 10
its kinda stupid to ask, but that means that the crank is 0.010 inch undersized right?
this corresponds to 0.25 mm undersized bearings ,ok?
thanks, Peter
Re: reground crank
February 11, 2007, 14:56:06 pm »
That's correct. It's common to grind a welded stroker or counterweighted crank to first undersize to make sure the journals are straight.
Re: reground crank
February 11, 2007, 15:42:05 pm »
thanks dude!
Re: reground crank
February 12, 2007, 20:41:20 pm »
jumpin on the wagon here!!! but how much can you safely go? i have one that is shipped to me and has been cut 0.5mm under. i know i can get bearings for this size but can you cut it again if nessecary?
thanks and sorry 'bout that
Re: reground crank
February 12, 2007, 23:52:53 pm »
0.50mm (20 thou) is common enough. Two more grinds available after that.
