September 22, 2026, 13:30:47 pm
engine buildup
Topic: engine buildup (Read 38314 times)
engine buildup
February 12, 2007, 19:27:47 pm »
hi guys,
got my parts a few days ago,
so thought i d share some pics
these are the things i have right now
dpr welded stroker( got a woody on that one
manton PR's
serrano PR tubes
magnums strait cuts (got a woody on those too
cb 5.5 h-beam rods vw journal
sump
equaliser pulley
cb wegdeports
cb 1.4 rockers
cb light weight wrist pins
mahle 94b's
scat 8 mm studs
thats about it
finally gettin closer......
cheers, peter
Re: engine buildup
February 12, 2007, 19:28:51 pm »
another one from the crank
lowfastbus
WUNDERWAFFE
Re: engine buildup
February 12, 2007, 20:04:04 pm »
Hey Peter,
Looking very good, you'll be happy with the DPR crank and wedgeports ...
Don't let that equaliser pulley anywhere near water... they rust like hell
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
Re: engine buildup
February 13, 2007, 00:06:39 am »
thanks jelle!
if it rusts like hell, maybe it can be anodised?
worries for later
Re: engine buildup
February 13, 2007, 05:04:58 am »
You cant anodize steel
Re: engine buildup
February 13, 2007, 21:01:19 pm »
damn,
gold plated then
Re: engine buildup
February 19, 2007, 18:51:47 pm »
guys,
the sump i got is the wrong type...
it s a 1 1/2 quart, instead a 3 1/2 sump
would this effect the oil cooling a lot if i keep it?
thanks
Jordy/DVK
Re: engine buildup
February 23, 2007, 18:14:12 pm »
Quote from: ruff on February 19, 2007, 18:51:47 pm
Sumps aren't the most expensive parts. If you're not in a hurry, put this one up for sale and buy a 3,5qt...
I don't know whether it's really necessary...
Just curious, but what size crank is it that you use? And which lifters?
Last Edit: February 23, 2007, 18:24:20 pm by Jordy/DVK
DVK ~
"The Full-Throttle Cruisers"
1951
medium brown splitwindow beetle
(resto in progress)
1968
Cal-look(-a-like)
(my daily driver)
Re: engine buildup
February 23, 2007, 19:45:58 pm »
hi,
the cra
Re: engine buildup
February 23, 2007, 19:48:09 pm »
the crank is welded, stroked vw crank by dpr,
cheers, Peter
Jordy/DVK
Re: engine buildup
February 23, 2007, 20:00:59 pm »
Yeah.. but what size? 82mm ? Can't find any clues for the size of your engine...
And lifters? Do you use Lube-a-lobes or cb lightweight?
DVK ~
1951
(resto in progress)
1968
Cal-look(-a-like)
(my daily driver)
Sander/DVK
Re: engine buildup
February 23, 2007, 21:55:05 pm »
Welded cranks are always 69mm.
Correct me if im wrong
Re: engine buildup
February 23, 2007, 22:02:43 pm »
nope... you can have a welded stroker.
Jordy/DVK
Re: engine buildup
February 23, 2007, 22:12:56 pm »
Look for DPR or DMS / Demello at thesamba and be amazed Sander..
DVK ~
1951
(resto in progress)
1968
Cal-look(-a-like)
(my daily driver)
lowfastbus
WUNDERWAFFE
Re: engine buildup
February 23, 2007, 22:13:38 pm »
I have a welded 74 mm in my engine... Peter aka 'ruff' told me the size of the crank he has, and it's bigger than 74... what size exactly I forgot.
WUNDERWAFFE
The Knuckle Buster
Sander/DVK
Re: engine buildup
February 23, 2007, 22:31:38 pm »
Hmm, I have learn something today
Re: engine buildup
February 23, 2007, 23:13:55 pm »
its an 82
engine will be 2276
lifters i dont have yet;
but i think i will buy udo's, so i dont have to worry about break in;
my engine will be megasquirt fed, so i can tune it right after the first startup
i ll have to start from scratch when tuning, so they will hopefully give me a peace of mind
cheers, Peter
Wunder Wim
Re: engine buildup
February 24, 2007, 12:47:31 pm »
Hi Peter,
I'm shure your EFi will give you all the things you are looking for: wide powerband and lots of torque...
C U
Wimme
http://dievolksfreunde.blogspot.com/
Grelland
Re: engine buildup
February 24, 2007, 18:38:41 pm »
Quote from: ruff on February 23, 2007, 23:13:55 pm
its an 82
engine will be 2276
cheers, Peter
I'm also working on a Megeasquirt engine, but just an 1835cc for now. What types of TBs are you going for? I will be using one centrally placed plenum.
Good luck.
Last Edit: February 24, 2007, 23:33:50 pm by Grelland
___________________
Roy
Re: engine buildup
February 25, 2007, 16:41:01 pm »
hellow,
i think i ll buy the TBs from CB;
on my 1700 i had the ones i m selling now; 40 mms from amt
i'm staying with the megasquirt, because its fun tuning your motor with a laptop:)
only if there were TB's that looked like IDA s
then i would have best of both
Jordy/DVK
Re: engine buildup
February 25, 2007, 17:21:30 pm »
Quote from: ruff on February 25, 2007, 16:41:01 pm
There are!!
Jenvey's and Redline Weber have IDA TB's... and some others too...
(but someone advised me to look for other TBs than Jenvey's)
http://www.redlineweber.com/html/throttle_bodies/Throttle%20bodies_ida.htm
http://www.jenvey.co.uk/drawings/index.htm
Last Edit: February 25, 2007, 17:23:30 pm by Jordy/DVK
DVK ~
1951
(resto in progress)
1968
Cal-look(-a-like)
(my daily driver)
Wunder Wim
Re: engine buildup
February 26, 2007, 17:36:24 pm »
Hey Peter,
they do exist, those TB that look like 48 IDA's. I found them on the web and are produced by Jenvey Performance in the UK. Just check out
These TB fit IDA intake manifolds, have almost the same dimensions and are obtainable up to 50mm...
A belgium company called AK Sport which is based in Brussels can deliver these nice TB's. They are not cheap, I allready ask price for IDF style TB in 48mm and cost 625 euro/pair.
What's the price for your current TB's?
Greetz
Wim
Re: engine buildup
February 26, 2007, 18:05:51 pm »
my tb's alone were about 400, without injectors and filters
i paid 250 for the injectors
i think the ida bodies almost look the same as idf bodies; and they cost alot more!
nobody has some junk ida's that i can use as tb's?
