July 02, 2026, 18:19:37 pm
bigsiembowski
Fuel pressure on 51,3mm IDA.
Topic: Fuel pressure on 51,3mm IDA. (Read 4189 times)
Kiel
February 10, 2010, 21:18:07 pm »
Hi.
How high must the fuel pressure be on a set of 51.3 mm ida, for max power ? ( 3 psi )
The carburrators have bin fittet whit original weber 300 needle valve.
best regards
Thomas kiel
PS:
http://www.youtube.com/v/T0IsZAJPlgg
Last Edit: February 10, 2010, 21:36:22 pm by Kiel
bang
Re: Fuel pressure on 51,3mm IDA.
February 10, 2010, 21:24:34 pm »
i run 0,3 bar on mine.
SteveW
February 10, 2010, 21:25:38 pm »
I always ran mine at 3.5 PSI. Just beware of the small fuel pressure guages there not entirely accurate!
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
February 10, 2010, 21:29:56 pm »
If you get the 3.0 needle valves to seal with 3.5 psi you`re lucky. Remember that the glass needles are light and has bigger area = you do not need so much fuel pressue to deliever the same amount of fuel. I used 2.3-2.4 psi on mine, any more and the junk glass needles would not seal. Remember to check the float level carefully.
Best rgs
BB
