November 04, 2026, 19:42:40 pm
| | |-+  Gauges in the glovebox pics
Author Topic: Gauges in the glovebox pics  (Read 6719 times)
pupjoint
« on: February 14, 2010, 12:15:39 pm »
initially wanted to cut up my dash to fit the VDO series 1 gauges, now reconsidering. a bit heavy hearted to cut my virgin 66 dash. i like how these gauges look on Bill Schimmer's car though.
i have
3-3/8 series 1 tach
52mm CHT
52mm oil temp
52mm oil pressure
52mm petrol gauge (optional to fit in he car, i can use the stock gauge)
52mm voltmeter (optional to fit)
52mm ammeter (optional to fit)
52mm Autometer AFR gauge
dun think i can stuff all inside the glovebox
Adele AW
« Reply #1 on: February 14, 2010, 12:44:42 pm »
Rather than cutting the dash for the guages, we have autometer carbon oil pressure and oil temp guages in our glovebox! I like the look personally, but we used the original trim too, i think you can just see in the pic below! You can also just replace the lid in future if you wanted !
O/FF 621
volksnut
« Reply #2 on: February 17, 2010, 00:16:54 am »
I've had this for years, in fact that's why I built my late model Cheesy
« Last Edit: February 17, 2010, 00:18:25 am by volksnut » Logged
« Reply #3 on: February 17, 2010, 01:09:32 am »
All of those in the glove box?! No way. Gauges were meant to be seen, not hidden.
Kaferdog
« Reply #4 on: February 17, 2010, 04:46:33 am »
This belongs to my friend Ted...Very Clean..!... Cool
« Reply #5 on: February 18, 2010, 20:19:51 pm »
That's awesome !
gizago
« Reply #6 on: February 18, 2010, 20:46:35 pm »
Absolutely, not much point in having them if you can't see em!
« Reply #7 on: February 18, 2010, 21:31:43 pm »
I did it like this, the beauty is that I still have a glove box that I can use when I shut the lid and I also belive you can make room for 5 instruments this way. You do not even have to drill if you find a strong enough glue.
Best rgs
BB
« Last Edit: February 18, 2010, 21:43:29 pm by BeetleBug » Logged
