September 24, 2026, 10:09:35 am
| |-+  For sale!
| | |-+  Aeromotive Fuel Pump, CB Pulley, Oil Cooler, Alternator.....
Author Topic: Aeromotive Fuel Pump, CB Pulley, Oil Cooler, Alternator.....  (Read 2581 times)
Adele AW
« on: February 14, 2010, 12:32:44 pm »
Stock Oil Cooler, very good condition, like new. £30
Fully polished Alternator with CB Billet Hex Nut and Pulley as pictured below £170
CB Sand Seal Pulley as in above picture, anodized Black £35
Aeromotive Fuel pump for Street/Strip High Output, in Excellent condition only on the car for 6 months 125
Pic and details below:
For High-HP Street Machines
Rated for continuous carbureted duty, both pump series have composite rotors, stainless steel vanes, heat-treated steel plates, and -8AN or 3/8" NPT ports. Also in a marine or show-quality polished Platinum edition.
Street/Strip Fuel Pumps
For carbureted engines making 200 to 750 HP with standard regulators or up to 1000 HP with dynamic bypass-style regulators. Ideal when more line pressure, flow volume, and reliability are desired. Flows 140+ gph at 13.5 volts and is alcohol compatible.
High Output Fuel Pumps
For carbureted engines making 200 to 600 HP without using a separate regulator. Internally regulated at 7 psi, these pumps should not require a separate regulator on most carbs. Ideal for high output street and mild race cars. Flows 90+ gph at 5 psi.
O/FF 621
SteveW
« Reply #1 on: February 14, 2010, 12:43:47 pm »
Just to point out that our pump is the 3/8 NPT version and the filters either side of the pump are not included Smiley
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
