November 04, 2026, 10:11:59 am
| | |-+  Lash caps loose or tight
Author Topic: Lash caps loose or tight  (Read 6889 times)
Felix/DFL
« on: February 17, 2010, 23:05:31 pm »
Hi Folks,
had that question in my mind for long.
What would you prefer? A loose lash cap or a tight lash cap?
The idea behind a tight cap is the the valves could turn and not just the cap.
I think it`s a question of does the valve turn in the head with a loose cap?
Pulling the tight caps is a real drama withou a fitting puller.Anyone got a pic of the Gene berg puller?
I want to set the valvekeepers tight at the valve (little gap)...
Maybe you have some experiences or better suggestions for me?
« Reply #1 on: February 18, 2010, 00:31:35 am »
You also want the lash caps tight so they don't work against the end of the valve.  See the photo of my Gene Berg lash cap puller below.
« Reply #2 on: February 18, 2010, 02:31:43 am »
After loosing a pair of the "loose" caps, I'm using Berg now.
Steve D.
« Reply #3 on: February 18, 2010, 02:50:56 am »
Loose fitting lashcaps are a diagnostic tool- if they fall off, you floated the valves... BAD!
Über Alles
10.77 avg. on pump fuel.
238I
Brandon Sinclair
« Reply #4 on: February 18, 2010, 03:42:39 am »
Donny,
Any chance you can post an upclose photo of the tip of that slide hammer-is there a window for the lash cap/stem to fit in?
« Reply #5 on: February 18, 2010, 04:14:17 am »
I'll give it a shot.
« Reply #6 on: February 18, 2010, 04:52:49 am »
OK see if this helps at all. [ Attachment: You are not allowed to view attachments ]
Felix/DFL
« Reply #7 on: February 18, 2010, 12:29:39 pm »
Thank`s for the pic`s and sugestions!
I will make me a puller like the GB puller and go with the tight one`s.
Everybody is setting their valve Keppers tight to the valve (grinded) or with play that the valve could turn as they come out of the packing?
Greetz!
« Reply #8 on: February 18, 2010, 13:04:53 pm »
Greetz!
Keepers not touching each other,tight to the valve Smiley
and personally I dont see any difference on the lash caps,as Steve D wrote,if they come off then something else is wrong
cheers richie,uk
