September 23, 2026, 07:18:00 am
| |-+  Wanted
| | |-+  4 dowel pins for 69mm CB crank
Author Topic: 4 dowel pins for 69mm CB crank  (Read 3498 times)
« on: February 21, 2010, 13:39:56 pm »
unfortunately, when you get machining done in Holland, some shops like to hold onto some of the tiny parts... think oil relief plugs, springs, bolts, and dowel pins as well. therefore, i'm hoping to source 4 dowel pins for a CB crank through a fellow lounger as it seems only extra length dowel pins are available new and i don't fancy drilling the dowel holes deeper myself. there's still 4 pins left in the crank though.
please let me know, and please excuse my grumbling  Wink
« Reply #1 on: February 21, 2010, 18:18:06 pm »
You can just use longer ones and grind them to the same length as the others,done it a few times
cheers richie
