September 24, 2026, 10:01:48 am
Gene Berg Ratio Rocker Set 1.40:1
Topic: Gene Berg Ratio Rocker Set 1.40:1 (Read 4004 times)
didi
February 21, 2010, 13:56:34 pm »
Used Ratio Rocker Set GB 411-140 in good used condition
370EUR shipped to your door inside Europe
more pictures available, please ask
Didi - Aircooled VW
http://didivw.blogspot.com/
germanvador
Re: Gene Berg Ratio Rocker Set 1.40:1
February 21, 2010, 20:26:41 pm »
hi didi, how many miles?
Where are the heavy duty rocker arm shaft studs, valve lash caps and the cup screws?
thanks
chris
Last Edit: February 21, 2010, 20:37:40 pm by germanvador
didi
February 21, 2010, 21:20:42 pm »
hi chris
i bought the rockers from albert bolleter, a swiss engine builder in the 90's. the engine was in the bay of his street driven typ2. the engine was a low power, high torque setup with stock valves an wbx (sr) cam. albert told me it drove approx 20'000km with it.
-the cup screws are gone with the pushrods.
-the lash cups and the head studs are gone with the heads, but i have a new set GB 369-8 lash cups and GB 409A-4 head studs if you are interessted.
didi
Didi - Aircooled VW
