September 01, 2026, 19:00:20 pm
| | |-+  Valve Covers??
Author Topic: Valve Covers??  (Read 10306 times)
« on: February 25, 2010, 18:17:12 pm »
Has anybody used these before? Any input?? Can't use stock covers, too much lift.  Undecided
http://www.bugpack.com/content.php?id=221
Ted
« Reply #1 on: February 25, 2010, 18:22:07 pm »
no input about these, but why not use Scats? they get good revieuws.
« Reply #2 on: February 25, 2010, 18:35:30 pm »
Which ones?
« Reply #3 on: February 25, 2010, 18:37:20 pm »
the stainless steel ones?
Yes they fit very nicely
Hotrodvw
« Reply #4 on: February 25, 2010, 22:06:09 pm »
M-Spec is making some saweeeet billet ones.  Not too pricey either.
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
181
« Reply #5 on: February 25, 2010, 22:40:27 pm »
thatīs what I had to do
 Grin
bugnut68
« Reply #6 on: February 25, 2010, 22:48:27 pm »
 Grin
That's what I want for my new 2017... I'm running an Engle 125, and probably 1.25 rockers, so I don't think clearance will be an issue.
Kaferdog
« Reply #7 on: February 26, 2010, 00:42:14 am »
Which ones?
Here it is Ted...These are what I was thinkin Too
80240T = SCAT Stainless Steel Valve Covers with 5 Tab Gasket Securing,Pair
« Reply #8 on: February 26, 2010, 02:14:59 am »
Ted
What kind of lift? I had a Clay Smith 320 with Pauter 1.4s with almost .600 lift on Comp Eliminators with .200 longer valves and the stock covers cleared, even with the bulky billet rockers. I would rather dimple the stock covers than bolt on a inevitable oil leak.
« Reply #9 on: February 26, 2010, 02:17:48 am »
 Grin
CB has new OEM VW Brazil covers for $12.95 a pair and bails for $5.95 a pair.
bugnut68
« Reply #10 on: February 26, 2010, 02:30:39 am »
 Grin
Do they have breather vents welded on?  I'll hafta take a look see at CB's web site.
« Reply #11 on: February 26, 2010, 02:56:54 am »
No vents, but that's fairly easy if you want the same as pictured.
« Reply #12 on: February 26, 2010, 10:53:48 am »
But why would you vent the valve covers?  Wink
bugnut68
« Reply #13 on: February 26, 2010, 17:40:44 pm »
Breather box? I probably won't be running an electric pump, so venting at the case in the fuel pump location isn't a real likelihood.
I'll have to find somebody that has a set already done or that can do the welding for me, since I do not possess this skill. Lol.  Cheesy
Brandon Sinclair
« Reply #14 on: February 26, 2010, 19:16:31 pm »
This guy offers them with the vents already welded-page down photos on right hand side..
http://www.awesomepowdercoat.com/products.html
I think Berg does as well.
bugnut68
« Reply #15 on: February 26, 2010, 19:48:11 pm »
Cool, thanks for the link!
« Reply #16 on: February 27, 2010, 13:49:06 pm »
it is not about the breather, it is about how you get the clearance for the rockers..
Dominick Luppino
« Reply #17 on: February 27, 2010, 21:13:30 pm »
What valve adjusting screws are you using? The only time mine ever hit was when I used the adjusting screws that came with my Scat rockers, I used the BUGPACK shorter screws, and problem solved...
« Reply #18 on: February 28, 2010, 01:28:23 am »
Hey Dominic, I'm using Berg rockers with there adjusting screws, BUT, I think I found my problem, my geometry was off, figured it out last night and redid it this morning. fixed the problem with taller lash caps and a reshim, but need to try the valve covers. BUT I still like the idea of the Bugpack race valve covers, now it's for looks. It's kinda Old School Thinking of wrinkle paint them with the polished rib's. Goes with the 3 1/2qt. Berg sump that I got from Berg sometime back that was black anodized with polished ribs. Still in the process.... Smiley
