October 13, 2026, 08:54:56 am
Setting endfloat query
Topic: Setting endfloat query (Read 4093 times)
RUSS74GHIA
VWSP163
March 04, 2010, 01:13:03 am »
I'm just getting my Type 1 bottom end sorted and thought I'd ask here before I call it finished.
The data I have says to set the endfloat to 0.07mm - 0.13mm, however I've read elsewhere that this should be increased to 0.25mm if the motor is +120bhp or will occasionally see the dangerous side of 6000rpm.
Any views/experience on this would be most welcome.
Russ
Last Edit: March 04, 2010, 08:36:48 am by RUSS74GHIA
Ivan
Re: Setting endfloat query
March 04, 2010, 01:20:20 am »
Have a look here at what Keith says;
http://books.google.co.uk/books?id=PuhW4TC-U00C&pg=PA23&lpg=PA23&dq=setting+end+float+on+a+VW+Type+1&source=bl&ots=ycYHZb6BPN&sig=APJPGI7_w8EY4NDabytspuZlj2g&hl=en&ei=A_yOS-_kAon14Aar_bSdDQ&sa=X&oi=book_result&ct=result&resnum=3&ved=0CAwQ6AEwAg#v=onepage&q=&f=false
It's worth buying yourself a copy
