November 04, 2026, 14:09:57 pm
| | |-+  another beam/dropped spindle question....
Author Topic: another beam/dropped spindle question....  (Read 6320 times)
beetletom
« on: March 08, 2010, 18:13:33 pm »
is it ok to run cb dropped spindles on a stock width beam with adjusters
running on 66 steels and 135/70 tyres?
gizago
« Reply #1 on: March 08, 2010, 20:06:13 pm »
You running drums, or a disc conversion?? The spindles will push the track out a bit, but with 135's you should get away with it if you're still on drums, if you dont go too low.
beetletom
« Reply #2 on: March 08, 2010, 20:13:57 pm »
yep, still wide 5 drums
thanks!
« Reply #3 on: March 08, 2010, 21:19:59 pm »
You *should* be ok as long as you don't crank the beam down too far.
« Reply #4 on: March 09, 2010, 04:51:54 am »
Plus with stock wheels you will have no problems either.
mcmscott
« Reply #5 on: March 09, 2010, 05:40:57 am »
Don't you have anything better to do? ;)quote]
« Reply #6 on: March 09, 2010, 05:48:29 am »
You'll be fine if you're running drums. I'm running the C.B. two and half inch drop spindles and have had Flat Four BRM and four and a half 356 wheels with both 135 & 145 tires with zero rubbing or any problems.
« Reply #7 on: March 09, 2010, 14:32:29 pm »
Don`t you?
beetletom
« Reply #8 on: March 09, 2010, 15:06:58 pm »
thanks guys!  Cool
