September 25, 2026, 20:35:38 pm
| |-+  For sale!
| | |-+  MSD Digital Multi-Retard/Autometer fuel pressure regulator-SOLD!
Author Topic: MSD Digital Multi-Retard/Autometer fuel pressure regulator-SOLD!  (Read 2414 times)
Tekken
www.proturbovw.com
« on: March 11, 2010, 22:26:47 pm »
MSD Digital Multi-Retard PN 8975.
"These MSD Digital Multi-Retard timing controls provide four different stages of retard, along with an adjustable start retard feature--with no modules! These units use a high-speed RISC micro-controller to direct the timing functions. This controller can make extremely quick compensations to the timing, while maintaining accuracy to within 1 degree. These circuits are thoroughly de-bounced and isolated for protection against Electro Magnetic Interference (EMI). There is also an innovative magnetic pickup compensation circuit built-in to allow for rock-steady timing with a variety of different mag pickups. There are four separate retard stages that can be activated independently or together for a total sum of retards. Each stage is adjustable from 0-9 degrees, and a maximum of 20 degrees of retard can be pulled out. On top of these great features, there is also an optional start retard circuit that can be programmed to retard the timing 5, 10, 15, or 20 degrees during cranking. Digital multi-retard timing controls can be used on 4, 6, or 8-cylinder engines, and must be used with an MSD ignition control"
As new,100 Euro.
SOLD
Autometer Pro Comp fuel pressure regulator,2 5/8"
Gauge Style  Auto Meter Pro-Comp
Sending Unit  Electrical
Gauge Type  Fuel pressure
Gauge Range  0-15 psi
Gauge Size (in)  2 5/8 in. diameter
Gauge Size (mm)  67.00mm diameter
Sweep  Full sweep
Gauge Face Color  Black
Gauge Number Color  White
Pointer Color  Orange
Bezel Color  Silver
Liquid Filled  No
OEM Replacement  No
Sending Unit Included  Yes
Quantity  Sold individually.
Notes  This gauge is not designed for use on a Dodge diesel.
Gauge Series  Analog
Footnotes  21 - Full sweep, stepper motor meter movement.
22 - Includes 1/8 in. NPT sender.
29 - Includes 8 ft. tubing or wiring harness.
As new,90 Euro.
SOLD!
Stian
« Last Edit: March 13, 2010, 18:15:59 pm by Tekken » Logged
JIMP
« Reply #1 on: March 12, 2010, 08:09:52 am »
Hello Stian
you have pm
Dimitrios
