September 21, 2026, 23:07:28 pm
| | |-+  '66 turbo bug
Pages: 1 ... 3 4 [5] 6 Print
Author Topic: '66 turbo bug  (Read 154086 times)
wolfswest
« Reply #120 on: March 28, 2011, 09:41:35 am »
I saw the car at vowo show last saturday, WOW, looks absolutely stunning!
great job.  Wink
Dem
« Reply #121 on: March 28, 2011, 10:13:09 am »
yes very nice car john
thejohn66
« Reply #122 on: March 28, 2011, 20:16:24 pm »
thanks for the comments, there is a good weeks work left to get it completely finished and following the mission getting it there it was reward enough having it in the show. Getting a top 20 was a very unexpected surprise!
Bitburg motor boating club member.
thejohn66
« Reply #123 on: May 03, 2011, 00:46:36 am »
 Shocked
« Last Edit: September 11, 2011, 20:43:11 pm by thejohn66 » Logged
thejohn66
« Reply #124 on: November 10, 2011, 20:24:11 pm »
Quick update, and a belated thank you to all who helped me finish the car and get it to Volksworld, you know who you are Wink. I have had the car on the street now and first drive out took me to Santa Pod for Bug Jam 25 where it didn't miss a beat on the way up. Unfortunately it blew the oil cooler up there on the saturday, so the sunday was spent under it swearing, hot and covered in oil. It drove home faultlessly though. I also took it out to a show in East Sussex where it won best pre '67 beetle and ran fine. Next was back to Santa Pod for its first run on the track. It drove there faultlessly and once there I signed on to race. First time on the track for both myself and the car so no hero stuff here, but after "driving" it gently off the line and "driving" it up the track it ran a 15.44 @ 92.18mph. Car is still only running 10psi boost so I was pleased that it felt planted and ran really straight. Next run out I put it into race mode, big burn out, up to the line and launching at around 4000rpm, gearbox went bang big time! Car is now parked up over winter while I am saving for parts, which I have sorted most of now. Weddle chromo main shaft with 1st and 2nd gears. German splined 3.88 ring and pinion with early 4-bolt pinion bearing and a new Magnesium rhino case. Hoping to get a quaife diff in there if money allows. It will be out again next year. I need to firstly sort out the traction issues (think it is just shock absorber adjustment) and run it as is for now. I think there is a 13 in it as is, then I will up the boost and see what happens Grin
ouch! panic set in, should have stopped immediately Roll Eyes
« Last Edit: November 10, 2011, 20:29:18 pm by thejohn66 » Logged
thejohn66
« Reply #125 on: November 18, 2011, 14:44:53 pm »
First installment of new gearbox parts arrived today Grin Thanks Eddie from Painters  Grin
Fasteddie63
« Reply #126 on: November 19, 2011, 04:10:58 am »
Your Welcome Alex,Good Luck Buddy
« Reply #127 on: November 19, 2011, 09:21:11 am »
I would have shot peened the ring'n pinion for max strength and done what ever possible to prevent flexing in order to keep your R/P alive. When you have done whatever possible to make sure its up to the task I would focus on how you pre-load your car. Last I would have saved enough money for spare gearbox so when this one breaks you are not out of the season.
-BB-
thejohn66
« Reply #128 on: November 20, 2011, 10:34:05 am »
-BB-
Yes, I agree that shot peening may well be a plan. I did try and pre-load the box on launch with the handbarake but unfortunately I think that there needs to be some work done on suspension set up next time out because there was apparently some wheel hop present. The car cannot really be tied in any more than it is already so I think stiffening up the rear shocks should help with this. As for saving up for another spare box, well I am struggling to get the money together for a replacement box, never mind an additional spare! The car is mainly a street car so hopefully this "built" box will stand the test of time, especially if I don't get too carried away  Grin
thejohn66
« Reply #129 on: June 02, 2012, 20:49:34 pm »
Nearly finished my new exhaust, quite pleased with how its turned out but I need to finalize the last angles Wink
dannyboy
« Reply #130 on: June 02, 2012, 21:23:32 pm »
lovely job mate, about time you came out to play again Cool
8.77@156.8mph
O/FF 60
thejohn66
« Reply #131 on: June 02, 2012, 23:07:01 pm »
Thanks Danny, getting it all ready for the new gearbox Wink
« Reply #132 on: June 03, 2012, 00:28:16 am »
-BB-
The car cannot really be tied in any more than it is already so I think stiffening up the rear shocks should help with this.   Grin
Actuallly there so more stiffening that you can do and need to do -- having fought this issue with my '56 this is what cured it  -- You need to tie in your roll cage to the trans horns right near where you rear solid trans mounts are at -- once that is firmed up and tied in most of your wheel hop will be gone -- QA1 shocks from Lumus will help a ton also
thejohn66
« Reply #133 on: June 03, 2012, 18:57:47 pm »
-BB-
I think you are right, so I am going to investigate and see how difficult it will be? I am thinking about solid mounting the whole lot now, I know it will be noisy but I can put up with it.
andy54
« Reply #134 on: June 07, 2012, 18:31:22 pm »
will you be now known as 2pipes Grin Grin Grin
thejohn66
« Reply #135 on: June 07, 2012, 21:39:24 pm »
There is only one 2 pipes Wink Grin
jamiep_jamiep
« Reply #136 on: June 12, 2012, 09:11:35 am »
That looks great Alex.
dragvw2180
« Reply #137 on: June 12, 2012, 16:46:38 pm »
    I have tied my cage to my frame horns exactly as you did and did not have any problems with them , but I do think your motor and tranny mounts are flexing on your launch. I agree with you that solid mounting both may eliminate your tire shake, beautiful car and well built. Mike McCarthy
thejohn66
« Reply #138 on: June 14, 2012, 19:28:11 pm »
Thanks Jamie  Wink
Thanks for your kind comments Smiley I think it will go solid mounted and also put a removable rose jointed brace between the gearbox cradle and the rear stay of the cage as it will be far easier to do it now and it certainly cannot cause any harm, Alex
thejohn66
« Reply #139 on: February 10, 2013, 21:14:22 pm »
DTA fitted, new gearbox fitted, MOT done, time to book the rolling road Smiley
Shag55
Shag Leone, SL-1racing
« Reply #140 on: February 13, 2013, 17:45:46 pm »
You have the coolest gas tank I've seen yet!
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
thejohn66
« Reply #141 on: February 13, 2013, 22:00:14 pm »
cheers, my mate Pete did well. He has done another one since for a german look car which is more complicated and intricate than my one.
thejohn66
« Reply #142 on: February 19, 2013, 18:18:36 pm »
71CALRIPPER
« Reply #143 on: February 19, 2013, 18:59:24 pm »
Dude what front tyres are you running ?
thejohn66
« Reply #144 on: February 19, 2013, 19:38:40 pm »
michelin xzx 145 80 15  Smiley
« Last Edit: March 03, 2013, 09:59:36 am by thejohn66 » Logged
thejohn66
« Reply #145 on: March 15, 2013, 08:33:37 am »
Finally got the car mapped on the dyno yesterday. They managed to get  a nice smooth power curve and 233hp @ 10psi followed by 265hp @ 16psi. Compression on my engine is set at 7.4:1 so 20psi should be fine. Pleased with that, already feels lively on the street!
« Reply #146 on: March 15, 2013, 09:27:53 am »
Congrats! At the wheels?
thejohn66
« Reply #147 on: March 15, 2013, 09:36:56 am »
Unfortunately not Sad  235 @ wheels  Wink
Andy Sykes
« Reply #148 on: March 15, 2013, 16:06:19 pm »
nice one we should see a 12 soon then Smiley
thejohn66
« Reply #149 on: March 17, 2013, 18:23:37 pm »
Nearly ready for drag day   Smiley
« Last Edit: March 17, 2013, 20:07:44 pm by thejohn66 » Logged
