June 10, 2026, 04:51:54 am
mvptkfjb
The New CB Distributor.....
Topic: The New CB Distributor..... (Read 13512 times)
March 19, 2010, 07:46:35 am »
Has anybody used the new CB distributor, the one that plugs in the MSD box? If so any feedback on how it ran? I hear it's kinda of a copy of the MSD dis. But all billet with bearings. Below is the link to there Dis.
http://www.cbperformance.com/catalog.asp?ProductID=432
Ted
Last Edit: March 19, 2010, 07:49:19 am by racecraf
Carsten
Re: The New CB Distributor.....
March 23, 2010, 11:36:38 am »
No one
Thinking of it , too
1969 IRS bug
benssp
www.callookvw.com
March 23, 2010, 13:30:33 pm »
looks just like the Pertronix one
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
Carsten
March 23, 2010, 13:35:31 pm »
Quote from: benssp on March 23, 2010, 13:30:33 pm
Yes , found that one on summitracing...Looks very similar , so would be interesting if someone has the possibility to hold all three of them in hands. my opinion of the MSD one is not the very best , had one in my last engine , had corrosion after short time and a little play in the shaft and a very much used looking cap after only 3500 kilometers...
So some more technikal informations would be interesting .
Carsten
1969 IRS bug
glenn
March 23, 2010, 14:10:11 pm »
They all look alike to me, but the question is do they all work a like?
Procomp
Pertronix
CB
MSD
Glenn
74 Beetle Specs
74 Beetle Restoration
2180cc Engine
www.DasVolks.com
Long Island's Aircooled Club
smallblockcoupe
March 24, 2010, 09:12:29 am »
Fwiw, those distributors all use the same cap. It's a chrysler design I believe from a jeep or something...totally available at any autoparts store.
Lawlessjr
March 25, 2010, 04:13:12 am »
Hi, My name is Mark I work over at CB. This distributor is a new product for us. It has adjustment springs and different bushings that allow you to change the total advance and the speed at which it advances. We have two different versions, One is plug into a coil and go and the other is a Magnetic pick-up type for using a MSD type ignition box. I put the manual on the website so you guys can scroll through it. If you have got any questions, just let me know.
http://www.cbperformance.com/pdf/Magnaspark%20II%20Distributor%20Instruction%20Sheet.pdf
Mark
Steve D.
March 25, 2010, 04:57:23 am »
Quote from: smallblockcoupe on March 24, 2010, 09:12:29 am
Nope, cap is four cylinder ford- rotor is GM non-HEI (E-type).
Über Alles
10.77 avg. on pump fuel.
238I
March 25, 2010, 06:08:13 am »
Ok, I had been talking with Pat Downs before the distributor came out. CB/Pat had the prototype distributor at I believe last year @ Bug-in. It caught my eye and I started asking questions to Pat, needless to say I was very interested. Meanwhile I had been bugging Pat when it was coming out. Pat was very helpful with that info. Anyway, CB had brought the distributors to Drag Day, my eye's opened up, I talked to Pat but was hesitant to get then, not because of the distributor, but more cause I was running my car and wanted to save the money just in case I broke. SO, after that day I made this post just to see if anybody had bought it and to see what they thought. While the next day after the post, I went to V-Dub Parts and picked one up, what the hell. So far had not been able to put it in yet cause I broke my toe. But just by looking at it and what Pat and I have discussed, this is one nice distributor. Not taking anything away from MSD, cause that is what I'm running now, but the CB is a one piece billet, bearings, very well crafted. It will hard to compare my MSD to CB cause Rodger Crawford had my MSD a few years back modified. But will be pretty close. I think I can cross over the springs and the stop to the CB, will see. The Ingnitor II billet distributor I also have on my other motor, also a nice piece, but kinda limted to what you can do, but still worked well for me. When I get the CB in, I will post my findings. I'm sure I will be not disapointed. But if anybody else did buy one of these distributors, post your findings.
Ted
March 25, 2010, 09:41:33 am »
Quote from: racecraf on March 25, 2010, 06:08:13 am
Ted
You fit distributors with your feet?!
That's some talent!
Seriously, I think it's good that CB and others are working on developing new parts all the time, and even though I'm unlikely to buy it in the near future (I've already got an MSD and a magneto) it's nice to know that these parts are there.
April 21, 2010, 07:38:26 am »
Ok, a little update with some pics. Got the CB distributor in and running. I like it, has a tighter advance, very clean setup looks just like the MSD inside. Will run the car tomorrow (Thursday) to see how the performance is.
Ted
DKO
April 21, 2010, 08:30:25 am »
with the CB distributor for ignition boxes...do you need an extension lead ? my box is under the back seat..don't reckon the standard wire will reach. do CB sell these ?
if not can you use the two wire coil version with an MSD box and just wire it to the coil ? what is the advantage of the magnetic pick up ?
thanks in advance
April 21, 2010, 23:26:25 pm »
It's exactly like the MSD, same plug and all. I just took out my MSD distributor and put in the CB one, plugged it in timed it, and Off I went. Well, you do have to change the clamp back to the VW one. No special clamp needed. Runs like the MSD if not better!
Ted
rick m
April 22, 2010, 15:56:14 pm »
Ted,
Thanks for the feedback. Just picked one up to run with my 6AL on my chop top.
Rick M
Rick Mortensen
Driving Hot VWs since 1970
m.m.p
April 23, 2010, 20:28:11 pm »
[/quote]
[/quote]
there is nothing new about this distributor!!!!!, its a copy of a copy of a copy!!!, its only NEW cos its not secondhand, dont get me wrong, i like CBs products but this is just a distributor!!! if it was a 3D crank trigered ignition system then i would be impressed
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
April 24, 2010, 00:55:46 am »
This is better than the MSD, it's 100% billet, also, it's bushed at the bottom, and at top is supported by a bearing, so to me it's a better design. The other MSD dis's that I've seen are all billet, so why not the VW one? Anyway, I see your point, but it's hard to compare when you got a better design and CHEAPER.
Ted
April 25, 2010, 01:32:44 am »
Quote from: rick m on April 22, 2010, 15:56:14 pm
Ted,
Rick M
Hey Rick, ya get it in yet? How does it work for ya,
you
see any difference?
Ted
jamiep_jamiep
April 26, 2010, 08:26:23 am »
The last MSD distributor I used seemed like it had been assembled by a blindfolded ape using a fork and a spoon.
If CB have improved what is a good design, poorly executed then hats off to them.
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
April 26, 2010, 08:57:38 am »
Quote from: kaferboy on April 26, 2010, 08:26:23 am
Well put. I sure they will at Bug-In 35, ya can go by and check'em out, that's what I did and thats what got me sold,A QUALITY PART.
April 26, 2010, 14:17:17 pm »
Quote from: m.m.p on April 23, 2010, 20:28:11 pm
[/quote]
[/quote]
I didn't think you'd be that impressed Marco, I know you like your electronics!
Superb job on Adele's EFI by the way, I love the way the throttle bodies are fitted to the IDA manifolds - took me a while to work out how you'd done it and I still had to ask Steve how it was done!
airstuff
April 26, 2010, 16:41:59 pm »
This distributor is the best bang for the buck
But,I am curious a little bit about it.
Which ignition module does the standalone version have?
