September 22, 2026, 13:30:44 pm
| | |-+  fuel tank fitting?
Author Topic: fuel tank fitting?  (Read 11173 times)
m.m.p
« on: March 31, 2010, 13:35:53 pm »
dose anybody know the thread used on the bottom of the stock gas tank?  also dose it change with different years?
thanks
marco mansi.........
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
Rocket Ron
It's old school for a reason
« Reply #1 on: March 31, 2010, 13:41:02 pm »
don't know the size but these may be useful , I think the are the same for all years
http://www.thesamba.com/vw/classifieds/detail.php?id=858097
13.12 @ 101.84
Grooving out on life
m.m.p
« Reply #2 on: March 31, 2010, 14:03:07 pm »
i hate those adaprers!!! there a nightmare! so you fit the adapter then you need a 90deg fitting witch makes the fitting too close to the track rod arms!!!!  so im going to be making some that are 90deg on the fitting Wink
Marco Mansi
0044(0)7947 660 924
Rocket Ron
« Reply #3 on: March 31, 2010, 14:17:43 pm »
if your are making some up I'll have one in AN - 8
I've an early ghia tank in the garage. I also have a spare tank fitting in the garage somewhere for my early 70's bug I'll see if it fits on the ghia tank for you tonight
thanks
 Ron
« Last Edit: March 31, 2010, 14:20:44 pm by On the edge » Logged
13.12 @ 101.84
pupjoint
« Reply #4 on: March 31, 2010, 15:01:53 pm »
let me know if u r making some
The Ideaman
« Reply #5 on: March 31, 2010, 15:07:35 pm »
Don't you just tap the bottom of the tank with 1/4" NPT?  Then use a 1/4" NPT to -6 or -8 line.
It is the soldier,
Who salutes the flag,
Who serves beneath the flag,
Lanny Hussey
« Reply #6 on: March 31, 2010, 15:19:21 pm »
Great trick..Hint, it's very, very easy to crack the housing by tapping too deep. Wink
« Reply #7 on: March 31, 2010, 20:46:16 pm »
Did that on my current tank, new tank has welded bung.
Rocket Ron
« Reply #8 on: March 31, 2010, 21:34:22 pm »
forgot I had one of these
http://www.cbperformance.com/catalog.asp?ProductID=1451
just tried it on my 56 ghia tank and it fits . the CB description says all tanks to '79
hope that helps
regards Ron
13.12 @ 101.84
WhiteTrash
« Reply #9 on: March 31, 2010, 22:03:06 pm »
Marco,
The size does not change. I've used a 59 tank which originally had the reserve tap lever through the bulkhead in a later car with standard pipe take off. Don' know the thread size but it's very fine.
VDub parts sell a blue anodized AN -6 and -8 adapter made from ally which is alot shallower then the one on the Samba ad from M-Tech. Richie got me one last year when i changed all my lines to AN and he recommended it. I use a 90 degree -8 fitting and it clears the tunnel and track rods ok.
If you are going to make one you'd have to make it a 90 degree direct fitting with swivel so it can be turned as to where you'd want it to exit. I doubt you could do that with a solid short 90 degrees machined piece and then get the nut over it. Basically it'd has to be a normal 90 degree tube style bend with a tank sized nut rather than the usual AN size. Quite a lot of work involved i think.
Frank
HOFF#67
JamieL
« Reply #10 on: March 31, 2010, 22:08:36 pm »
Hi guys,
don't know if this is an option or not, but I welded one half of a male-male -10 fitting to the bottom of the tank in my ghia and used the stock fitting as the return - seemed to work OK for me.
I basically cut the male thread off one half, welded it on the outside and then drilled through after - was then easy to fit a tight 90deg -10 elbow straight on, was lower profile than the stock fitting...
Good luck - hope you get it sorted Smiley
J.
« Last Edit: March 31, 2010, 22:10:44 pm by JamieL » Logged
m.m.p
« Reply #11 on: March 31, 2010, 23:09:40 pm »
Frank
hey Hoffman you must have faith!!! ill make one, M.M.P style!!!
Marco Mansi
0044(0)7947 660 924
Eric Justus
« Reply #12 on: March 31, 2010, 23:26:25 pm »
Lanny is correct. I went through 2 tanks on my ghia from cracking the first one. Back then, those fittings werent available and I had to tap the tank.
Eric Justus
HotVWs, SuperVW, Let's Play VW Cal-Look features
Der Kleiner Panzers VW club
WhiteTrash
« Reply #13 on: April 01, 2010, 13:00:51 pm »
I'm sure you will. Let us know when its done. Off course 1 adaptor less is 1 potential leak less.
Frank
HOFF#67
Kaferdog
« Reply #14 on: April 02, 2010, 17:28:47 pm »
Here another fitting ......
http://www.thesamba.com/vw/classifieds/detail.php?id=776010
« Reply #15 on: April 02, 2010, 22:11:14 pm »
The threads on the tank outlet are M18 x 1mm.
Best rgs
« Last Edit: April 02, 2010, 22:14:03 pm by BeetleBug » Logged
m.m.p
« Reply #16 on: April 09, 2010, 19:06:04 pm »
thanks BeetleBug , dose anybody know what a super beetle uses? is it different?
Marco Mansi
0044(0)7947 660 924
Hotrodvw
« Reply #17 on: April 09, 2010, 21:23:03 pm »
thanks
I believe it's M20x1.0.  I made my own out of the stock nut, but you can buy them too, obviously.  I like the 1/4" npt method too.......I've done it both ways.
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
67Screamer
« Reply #18 on: April 09, 2010, 23:08:10 pm »
thanks
The guy at Speedflow told me it was M18x1mm, that was on a fuel tank from a 67 Beetle.
m.m.p
« Reply #19 on: April 28, 2010, 20:38:27 pm »
ok, so this is the ProTurbo tank adapter im now selling Smiley
it has 4 X 3/8NTP outs, that ill allow from -6 to -10 Smiley so you can run two -10 out to your efi fuel pumps, a -8 return and a -6 to drain the fuel from your tank Smiley perfect
if you only want one out, just plug the ones your not using with NTP plugs
you can use the standard intank filter and washers Smiley
there £40 each
Marco Mansi
0044(0)7947 660 924
