October 13, 2026, 15:27:04 pm
| | |-+  Rocker arm side play/shimming
Author Topic: Rocker arm side play/shimming  (Read 4528 times)
reijo5
« on: March 31, 2010, 20:08:33 pm »
what should it be ? i have scat 1.25 on a engine that revs to 7k
will standard vw shims fit scat rocker shafts?
Thanks for help in advance  Smiley
Type1/DVK
« Reply #1 on: March 31, 2010, 22:01:36 pm »
There should be a bunch of shims with it. It is a pain in the *ss to shim it correctly, once done on the table and you mount it it CAN differ, so re measure.
I've used one std shim because this was perfect for that amount that needed.
Regarding to 5-6-7-8k or whatever, your play between rocker arm and shim should always be correct no matter what.
reijo5
« Reply #2 on: March 31, 2010, 22:12:10 pm »
Thank s  for that , did you messure the gap with a  feeler gauge? what did you set it at ? or just by feel ?
Type1/DVK
« Reply #3 on: March 31, 2010, 22:42:33 pm »
according to the cb instruction manual it must be set at 0.15mm, i've got them at best 0.10 or 0.15mm. Also note that the rocker arm must be OFF center of your valvestem (with std rockerarm screws), to give it that rotation.
