September 22, 2026, 07:09:18 am
| | |-+  Generators
Author Topic: Generators  (Read 4727 times)
« on: April 06, 2010, 22:30:16 pm »
Anyone still running a generator on their car or has everyone gone to alternators? I am tempted to run a gen on my Manx so I can run an early style fuel pump.
glenn
« Reply #1 on: April 06, 2010, 22:53:13 pm »
Take a look: <a href="http://www.youtube.com/v/zQ1sMb9CA44" target="_blank">http://www.youtube.com/v/zQ1sMb9CA44</a>
Glenn
www.DasVolks.com
Long Island's Aircooled Club
« Reply #2 on: April 06, 2010, 22:57:31 pm »
So it will fit, there is just not a lot of clearance.
edit: It looks like the issue is if you are running the stock carb which I am not. So I should be able to run that 32hp fuel pump I have with an alt. Then I just have to set the fuel pressure to work with the IDFs. cool.
« Last Edit: April 06, 2010, 23:03:11 pm by louisb » Logged
« Reply #3 on: April 07, 2010, 00:45:03 am »
I like how generators look. Simple, clean, and less bulky.
Cheesepanzer
« Reply #4 on: April 07, 2010, 02:53:38 am »
Me too, but I finally got talked into changing over to alternators in both my Ghia and Single Cab.  The alternator is just a better set up for providing a more efficient charging system.  Still, I might stick with a generator in my Thing project.   Wink
63 Type 2 Single Cab
Cornpanzers
« Reply #5 on: April 07, 2010, 05:14:31 am »
I still run a generator.
I like the less bulky look and I like having the reserve use of grounding it and using it as a motor to cool if and when I throw a belt. This has saved me a tow 3 or 4 times over the years.
Also, I use it in this capacity at the track for a little cooling.
181
« Reply #6 on: April 07, 2010, 12:11:39 pm »
I consider converting my engine to a 912 small dia 12V generator and correct porsche oil breather tower.. to obtain "cleaner" look.
« Last Edit: April 07, 2010, 12:13:26 pm by 181 » Logged
