June 09, 2026, 22:29:29 pm
Latest Member: mvptkfjb
| | |-+  What to use for preserving a case on the outside?
Author Topic: What to use for preserving a case on the outside?  (Read 12859 times)
« on: April 07, 2010, 23:56:43 pm »
After glass beading.
I have some older but good cases on the shelf that are not very nice on the outside. I have glass beaded cases before, but I have never  found the "super solution" to preserve the surface afterwards, so that it stays reasonably nice at least for a year or two. I dont like painting them for several reasons, heat being one of them.
But what else to do?
Let me hear ya!!
Torben
« Reply #1 on: April 08, 2010, 12:29:33 pm »
my only idea is Cosmoline, the same goldish stuff the factory used to preserve cast parts.
« Reply #2 on: April 08, 2010, 16:53:29 pm »
Torben, i use Valvoline wax spray-cans, the stuff you use to preserve youre sheet metal on the inside of
your car. You simply wash it off with thinner and the case is brand new again. (WD40 evaporates and the
oxidation starts again). My 2 cts.
besserwisser
« Reply #3 on: April 08, 2010, 22:59:12 pm »
I have found a cheap way of stopping the oxidation of magnesiumcases that is easy to wash away. The swedish company Biltema sells a linseed based corossion spray that makes the case dark and unsensative to oxidation. It washes away in my 90degree parts cleaner.  You spry it on, wait for a day and wipe the case down with a dry cloth. I have about 50 cases that have been standing around for 5 years with no corrosion.
pupjoint
« Reply #4 on: April 10, 2010, 12:11:35 pm »
never tried before, but for work, we use CRC's Softseal to prevent downhole tools from corrosion.
dunno how it works in mg cases.
KRS808
« Reply #5 on: April 13, 2010, 08:18:03 am »
Dow No. 7 (MIL-M-3171A TypeIV) for magnesium.
Alodine 1201 (MIL-C-5541) for aluminum.
Both are chemical conversion coatings which can be applied by spray bottle and neutralized by cold water rinse.
Hope this helps. Aloha
« Reply #6 on: April 13, 2010, 18:35:55 pm »
Try this: http://www.sharkhide.com/mpinfo.html
Haven't tried it myself, but I asked and they said it gives good results.
TxT
« Reply #7 on: April 20, 2010, 23:44:51 pm »
OK.
Thank you all.
There are a couple of solutions to try out.
(I will have to check what can be bought locally.) The Biltema solution could turn out to be the easy way out.
Dave Rosique
nobodyouno
« Reply #8 on: April 22, 2010, 02:08:48 am »
Hi Torben,
You glass bead your cases?? I've always thought it was a bad idea even with a through cleaning afterwards.
So... am I just old fashioned, or have I been wrong all this time?
Thoughts please Grin
Thanks!
  DR
« Reply #9 on: April 22, 2010, 03:31:02 am »
A couple years ago tony from wolfsburg west sent his stock 36 HP case out and had it recoated with some kind of gold colored plateing, Like original. Sorry I cant remember the name of the process. But it came out bitchen.
kingsburgphil
« Reply #10 on: April 22, 2010, 03:36:51 am »
Aircraft Spruce sells Mag treatment in a kit form.  Regarding glass beading a case, did it once. Cold tanked the case first, plugged all the oil galleys
and an hour in an industrial ultrasonic tank after glass beading. Got lucky, but I don't think I'd do it again.
P.S. the process Danny is referring to is called "chrome pickle", if I'm not mistaken  Cheesy
« Last Edit: April 22, 2010, 05:42:26 am by kingsburgphil » Logged
« Reply #11 on: April 22, 2010, 09:06:48 am »
Hi Torben,
Thanks!
  DR
Not always. But around here the weather is pretty harsh on the cases. And sometimes I get a case or two, that holds specs, but are very attacked by surface erosion. Then I get them glass beaded. But I do prefer "just" to steam clean them. Dry ice cleaning is also very good, but the guys I know that do that dont ride the same day they saddle, and it is relatively expensive.
Dave Rosique
nobodyouno
« Reply #12 on: April 22, 2010, 16:15:17 pm »
Hi Torben,
Thanks!
  DR
Got it!
Thanks for the reply. I must admit, I've used a few "ugly" cases that were otherwise good.
Additionally, I've never painted a case.
~DR.
« Reply #13 on: April 22, 2010, 16:56:52 pm »
I'd be really concerned with the "critical surfaces" such as the case parting line and oil pump bore when using abrasive media.  You could bolt it together to do the blasting I suppose?
Deadly1
« Reply #14 on: April 23, 2010, 04:37:17 am »
I recall a local shop back in the 70's that started glass beading their rebuilt motors. They looked fantastic but as I recall most of them suffered bearing failures from the left over glass beads. If we're voting I vote bad idea! wayne
OgCalLook
Straight outa Riverside!
« Reply #15 on: April 24, 2010, 02:55:56 am »
X2 on Bead blasting a case - bad idea = bearing failure!
The machine shop I use has a Hot water (scalding hot) parts washer. Cleans everything spotless.
Tom Hewitson
Bahama Blau Kafer
Zach Gomulka: "California Look is walking softly and carrying a big fucking stick."
kingsburgphil
« Reply #16 on: April 24, 2010, 03:56:43 am »
I concur, I used machines like that for decades. But finish wise, cases come out as they went in...by design.
Returning a case to original finish is a different story, here's a 71 case I used an aluminum cleaner on...mistake!
I tried using a soda blaster...better, but still not original. Next I'll try the Mag treatment kit that Aircraft Spruce
sells, after that it's chrome pickle($$$).
OgCalLook
« Reply #17 on: April 24, 2010, 04:19:50 am »
Nice Chandelier! ^^^
Joe Ruiz knows how to do it, but won't tell Smiley
Is this chrome pickling?
http://www.thesamba.com/vw/classifieds/detail.php?id=587241
« Last Edit: April 24, 2010, 04:22:02 am by OgCalLook » Logged
Tom Hewitson
Bahama Blau Kafer
kingsburgphil
« Reply #18 on: April 24, 2010, 04:42:01 am »
If it is, it's one step past what I'd call normal.  It's pretty, but as a child I don't recall my fathers new 55 oval having a gold engine block. Or his 59 bus or his 65 beetle either.  Of course, as usual I may be mistaken.
 I think these guys can help...www.techplate.com/
« Last Edit: April 24, 2010, 05:57:38 am by kingsburgphil » Logged
