September 24, 2026, 18:16:34 pm
where have you mounted your harness shoulder straps?
Topic: where have you mounted your harness shoulder straps? (Read 3250 times)
beetletom
April 10, 2010, 20:04:15 pm »
fitted my simpson harnesses a while ago, but finally fitted the sholder straps today
i used the 2 mounts in the centre below the rear seat, and the 2 bolts at the far corners of the rear crossmembers
is this ok?
the shoulder straps are as far expanded as they can go, but when buckled together, the harness catch is right in the middle of my chest!! the seat is in the most upright position too, as i find that most comfortable to drive like.
or do i need to buy longer sholder straps?
thanks.
