October 13, 2026, 03:08:43 am
| | |-+  Adapting a 356 breather to vw generator stand
Author Topic: Adapting a 356 breather to vw generator stand  (Read 11672 times)
« on: April 11, 2010, 20:28:09 pm »
First I bandsawed a round circle out of some alum plate, Then chucked it up in a lathe and counter bored a step for og nut for stock breather. Then machined a small step in stock nut to locate 356 tube on stock flange.
« Reply #1 on: April 11, 2010, 20:31:19 pm »
Cool thread - I have been thinking about this one for a while  Smiley
« Reply #2 on: April 11, 2010, 20:32:06 pm »
After everything fit I bolted all together and scribed outside of 356 flange on alum adapter plate and bandsawed to scribed line and grind and filed to proper shape.
« Reply #3 on: April 11, 2010, 20:34:24 pm »
Some finished pictures. and set on motor to figure out AN fitting and plumbing to firewall mounted breather
Griebel
« Reply #4 on: April 11, 2010, 20:45:39 pm »
Looking good ,Danny Cool
MIB member Morten Iversen aka "Tannheuser Tuning" did this "new model" conversion on his 2110 back in 05...
Instagram: c.griebel
       "BEYOND 4 INCHES"
          MIB,DENMARK
Gavin - DVKK
« Reply #5 on: April 13, 2010, 05:16:36 am »
Hey Danny, I like your flange idea... Did you taper some angle in the flange to allow the filler to sit more upright(otherwise it leans over to the right quite a bit). You could also just cut the snout on the stand and weld on the flange.
Test fitting down pipe:
« Last Edit: April 13, 2010, 05:44:49 am by Gavin - DVKK » Logged
« Reply #6 on: April 13, 2010, 05:29:19 am »
One of the best all time threads on here.
« Reply #7 on: April 13, 2010, 10:22:38 am »
sehr cool!  Wink
RFbuilt
« Reply #8 on: April 13, 2010, 12:13:36 pm »
hahaha yup.. thats what i said  when i was smoking some good stuff in the garage too!   Grin
youngnstudly
« Reply #9 on: April 15, 2010, 06:00:45 am »
The method Danny used is just how I am doing my mounting for the oil filler I have....Too bad mine isn't a 356 oil filler! Sad The "bandsaw, grind, file, and polish" method isn't very productive or as neat as the Milling/lathe machining processes, but I sure appreciate the end result more after putting in all the hard work! BTW, you do some really trick stuff Danny!
Andy
Geoff P DVKK
« Reply #10 on: April 17, 2010, 01:23:30 am »
Hey Gavin,
I think your breather was the most talked about item on your car at the Classic last year, Love that engine bay!
« Reply #11 on: April 17, 2010, 14:06:47 pm »
Also diggin the "twisted" dyno to help hide the wires  Wink
rick m
« Reply #12 on: April 22, 2010, 15:53:43 pm »
Do you know who sells the braided fuel lines on this motor with the banjo fittings for the IDAs?
Rick M
Rick Mortensen
Driving Hot VWs since 1970
Geoff P DVKK
« Reply #13 on: April 22, 2010, 15:57:02 pm »
Hi Rick, Those are aeroquip fittings that Gavin stripped the anodizing and polished.
Gary Justus
« Reply #14 on: April 22, 2010, 16:07:40 pm »
Rick M
Rick, I got mine at G&J Aircraft/Competition in Ontario. 909-986-6534. Depending on how long you're in town for Bug-In, you could swing by.
G&J Aicraft & Competition
1115 S. Sultana
Ontario, Ca. 91761
