October 14, 2026, 01:18:47 am
info. j&g floater
Topic: info. j&g floater (Read 10018 times)
bang
info. j&g floater
April 17, 2010, 21:09:16 pm »
hey. need info how to adjust a j&g floater clutch. also pictures how the discs have to be inside.
thanks
bigbangracing.dk
Re: info. j&g floater
April 18, 2010, 16:55:00 pm »
Do you have a single or dual disc clutch?
www.Udobeckertuning.de
bang
April 18, 2010, 18:06:22 pm »
single with geers black magic..
Tekken
www.proturbovw.com
April 18, 2010, 20:58:37 pm »
Hey!
First clutch disc,the floater with flat side against disc,and then diaphram.You need shims/stand offs between flywheel and diaphram/pressure plate to adjust the break away pressure.
Adjust the clutch with pressure setting via tourqe wrench.Put a flywheel lock on your flywheel install a input shaft with a socket welded on the end so you can check slipage with your tourque wrench pro turbocar =aprox.180lbs of torque for slipage Super street car about 160 lbs and a pro stock car about 130 lbs.
Stian
bang
April 18, 2010, 21:09:17 pm »
okay thanks.. tekken..
when are you redy for test run? remember we have some good reces in june here in denmark.
Tekken
www.proturbovw.com
April 18, 2010, 21:49:29 pm »
Quote from: bang on April 18, 2010, 21:09:17 pm
Hope to test May 8'th.Yes,maybe we're comming over if we can get the car to work good.When are you ready?
bang
April 19, 2010, 07:29:46 am »
my first race is also 8 of may.. the car will be in denmark 29 of april so have 9 days to get it all to work
but hope everything will work out okay.
April 19, 2010, 11:27:04 am »
Quote from: Tekken on April 18, 2010, 21:49:29 pm
Hi Stian
If everything works you can come to England at the end of may ?
Last Edit: April 19, 2010, 20:44:18 pm by Udo
bang
April 19, 2010, 11:38:34 am »
hey udo.. what race is there in the uk in the end of may?
April 19, 2010, 12:49:20 pm »
Quote from: bang on April 19, 2010, 11:38:34 am
Gary's Picnic at the Yanks Weekend - Udo and Ole came over in 2008, and we had 12 (I think) from DAS last year. It's a really good weekend, and if the weather holds out it's plenty of track time too!
http://www.shakespearecountyraceway.com/eventdetails.asp?event=67
April 19, 2010, 20:46:11 pm »
this is a good place and event for european racers to meet . i am working to be there too this year . So adjust your clutch and come over
Tekken
www.proturbovw.com
April 19, 2010, 20:53:53 pm »
Quote from: Udo on April 19, 2010, 11:27:04 am
Hi Stian
Hi Udo!
Would REALLY like to do so,but just have a lot of new things too test out first.I want to be sure that everything works good before we take the long trip to England,don't have enough time to sort everything out.But maybe we can work something out later this year.
