November 02, 2026, 19:55:34 pm
1.4's Switch to 1.4's ?
Topic: 1.4's Switch to 1.4's ? (Read 6622 times)
April 19, 2010, 22:34:59 pm »
Have a good question, Can you switch say, CB 1.4's say to Chinese 1.4's or even Scat 1.4's without cutting another set of pushrods? I would think they would pretty close. But never tried it. Any info would be greatly appreciated.
Ted
Re: 1.4's Switch to 1.4's ?
April 20, 2010, 00:33:32 am »
Ted,
I have no experience with those brands, but last year in a frantic reconfigure of my street motor for a race, I experimented with 2 ratios of Breg rockers as well as 2 pauters ... they were all quite close especially inside each brand, but for optimal results each would have had specific needs.
Take care,
Tom
Fasterbrit
April 20, 2010, 21:10:23 pm »
You need to be careful if you switch to scat 1.4s as they actually measure out at closer to 1.6:1 ! This can get you in to all sorts of problems with coil bind etc. The cb rockers are fantastic - I would stick with them
if I were you.
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
April 20, 2010, 21:35:00 pm »
Thanks guy's, but this is the problem, A friend of mine needs a set of 1.4's, I have a set of Chinese ones that were modified at Berg's with there shafts and hardware. I want to keep them but was thinking of loaning the set to him till he can get the CB's down the road. I have no problem loaning him the rocker's, but when he get's his CB's, will he be able to still use the same push rods? I hope this clarifies this better.
Ted
Martin
Cash Converter....
April 21, 2010, 08:09:26 am »
I think you'll be lucky if you can use the same pushrods. (I Think that was the original question)
Martin
www.taylormachine.co.uk
OFF/500
