October 13, 2026, 20:19:58 pm
| | |-+  piston balancing
Author Topic: piston balancing  (Read 6701 times)
Phil West
« on: April 21, 2010, 08:24:32 am »
I'm balancing my first set of pistons - I need to take off 3 grams.  I got the Fisher book but it's not very specific.  I'm thinking the wrist pin shoulders are a good place to start removing metal but it would be guesswork.  Can anyone suggest the best place to start grinding?  It may be easiest to use a clockface on this pic - so grinding the shoulders would be 3 oclock and 9 oclock.
Any help appreciated!
Phil 'The Drill'
« Reply #1 on: April 21, 2010, 10:41:22 am »
I removed 6g like that
(below the wrist pin on the shoulders)
 No problem Smiley
andy M.
« Reply #2 on: April 21, 2010, 10:52:26 am »
I'd go 10 & 8 and 2 & 4, leaves a bit of meat behind the pin,
andy
L.B.C.R.
m.m.p
« Reply #3 on: April 21, 2010, 12:22:49 pm »
DO NOT TOUCH THE PISTON!!!!!!!!!!!
weigh the pistons only, without the gudgeon pins, make a note of each piston, then weigh each gudgeon pin and make a note of it, then match the pistons with the gudgeon pins to get a close match with the weights, then take the weight ONLY OUT OF THE GUDGEN PIN!!!!!!!!!, you take the material out of the inside of the pins at each end, that way you wont weeken anything and steel weighs more so only alittle is needed to be taken out.
 Grin
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
Phil West
« Reply #4 on: April 21, 2010, 14:19:01 pm »
thanks guys.
Marco the wrist pins all came out the same weight  Angry so can't get anything more out of switching them.  Anyway I wish I had a lathe to turn out the inside of the pins - I'll have a careful go on the pillar drill.
Anyone know what the square lump on the wrist pin boss at 3 oclock is?  I'm guessing some sort of casting effect so that square lump could be removed.
andy M.
« Reply #5 on: April 21, 2010, 14:36:17 pm »
the lump is to distinguish which way the piston goes in the bore, it's on the same side as the arrow on top
andy
L.B.C.R.
« Reply #6 on: April 21, 2010, 15:29:40 pm »
..., then weigh each gudgeon pin and make a note of it, then match the pistons with the gudgeon pins to get a close match with the weights, ....
There's no point in doing this because the wrist pins will always be identical in weight.  Every dimension is controlled.
Phil, if you're using teflon wrist pins, don't try to open up the ID of the pins.  You won't be able to drill them anyway, they are much harder than your drill bits.
You can remove some material from the underside of the crown of the piston where the name Mahle is cast in.  Take off the bump at 3 O'Clock.  Taper the ends of the two ribs by the skirts.
Phil West
« Reply #7 on: April 21, 2010, 16:12:06 pm »
Yep just tried drilling the wrist pins and no go against my drill bits!  Lump removed - now all within 1 gram.
