September 22, 2026, 21:24:59 pm
One way fuel valve help needed
Topic: One way fuel valve help needed (Read 4217 times)
April 21, 2010, 11:30:04 am »
I want to keep my original fuel tank in my 56 oval race car.
Looking at the regs for uk drag racing I need to have a one way fuel valve/breather from the tank.
Someone recommended a valve that i could instal in the cap (drill through the cap) Any one suggest a suitable valve?
Also, can it just vent to atmosphere or do i need a line from it?
Re: One way fuel valve help needed
April 21, 2010, 16:43:49 pm »
Lee
For some reason tech at avon park gets really upset at vented caps,you can drill the filler neck and install a "fuel cell bulkhead fitting" then the roll over valve fits onto that,then use some hose or hard line to vent it outside the car
I used one like this
http://www.jegs.com/i/JEGS/555/15363/10002/-1
or this might be simpler
http://www.jegs.com/i/JEGS/555/15361/10002/-1
cheers richie
April 21, 2010, 20:19:16 pm »
Thanks Richie,
will the bulkhead fitting seal ok on the curved part of the
petrol tank filler neck?
Do you have a photo of your set up?
Lee
