September 09, 2026, 23:06:50 pm
Latest Member: Bad Habit
| | |-+  92 mm cilinderkit
Author Topic: 92 mm cilinderkit  (Read 4555 times)
FDK/mrpedrini
« on: April 24, 2010, 19:25:32 pm »
just wonder.....
What are the experiences on 92 mm cilinderkits? Making thougts to upgrade my 2017cc engine with a 92mm cilinderkit (2074cc). Are they to thin and is it true that they don't seal well in the head area?
kind regards, Dennis..
rick m
« Reply #1 on: April 24, 2010, 23:06:16 pm »
Buy the new style AnA set. It has a 94 outer and a 92 inner. Thicker than the 94 barrels and I have heard the work fine. I bought a set and have not installed them yet. I believe CB Performance may carry them.
Rick M
Rick Mortensen
Driving Hot VWs since 1970
« Reply #2 on: April 24, 2010, 23:19:03 pm »
You can get 94's that have been machined to fit in the 90.5 case, you have to machine your heads though... 2175cc!
FDK/mrpedrini
« Reply #3 on: April 25, 2010, 10:54:25 am »
Thanks for the reply's,
So i must presume that the regular 92 mm kit (without machinework to case and heads) is not advised to use? regards D
rick m
« Reply #4 on: April 25, 2010, 18:19:07 pm »
I would recommend using the type where you machine the case. You can then have the case faced so the seating areas are all trued up and have a wider base to support the barrels.  I have done this for all my VW life and it works the best.  There are guys who machine the bottom of the barrels but in my opinion it is a compromise to the cylinder integrity.
RM
Rick Mortensen
