October 15, 2026, 19:57:19 pm
Sealing stock fuel pump flange
Topic: Sealing stock fuel pump flange (Read 3423 times)
Brandon Sinclair
April 26, 2010, 15:49:31 pm »
I have a stock fuel pump on one of my type 1's and it weeps a small bit of oil from both above and below the flange. I have used permatex, tried loctite 518 below and used permatex spray on gasket sealer to the gaskets above the flange. I thought I had it licked but then after some 50 miles I see evidence of oil weeping again. Any suggestions on what sealant/procedure to use to stop this from happening would be great. Thanks
Re: Sealing stock fuel pump flange
April 27, 2010, 03:02:38 am »
Sounds like all of the mating/contact surfaces of the case, pump block, and pump need to be closely checked to make sure that they're congruent. That's all I can offer... I've never had one leak. But good luck with it, at any rate. Hopefully, someone can post up a sure fire cure.
Brandon Sinclair
April 27, 2010, 04:08:28 am »
Thats what I was thinking too Fred. I guess I will grab a new flange and start there. Thanks.
