October 13, 2026, 05:01:04 am
| | |-+  wich rods length ????
Author Topic: wich rods length ????  (Read 7436 times)
EL PINGO 66
« on: April 27, 2010, 04:51:49 am »
hola amigos..
i wana biuld my 2276 but i not sure whit the length of mY rods..
this are the specs..
82mm cb crank...
12 lbs flywheel
eagle h beam 5.352 vw journal
94 b mahles
fk 10
SLR LIFTERS
044 ULTRA MAGPLUS 42 X37.5
1.4 ROCKER ARMS ERSON
MAGNUM GEARS
ESTIMATED COMPRESION 9.5 -10.1
48 IDAS
1 3/4 LOWDOWN 2 1/2 HOOKER MUFLER
MSD IGNITION
N¨ BLA BLA BLA.................
OK.. THE OTHER OPCION IS CHANGE THAT RODS FOR A 5.500...
THANKS
« Reply #1 on: April 27, 2010, 05:15:54 am »
Stick with the %.352s ... I've run them in my 2110, later 2276 for 12 years with no regrets or problems.
Love that short rod snap!
Just my 2 cents worth ...
Take care,
TxT
« Reply #2 on: April 27, 2010, 05:21:29 am »
Ditto!  I'm running them in my 2165 and all I can say is it's great...
EL PINGO 66
« Reply #3 on: April 27, 2010, 05:59:25 am »
OK  ..  SOUNDS GREAT....
5.352..  VS 5.500
2-0
 Roll Eyes Roll Eyes
Steve DKK
« Reply #4 on: April 27, 2010, 06:19:05 am »
2-1  If you are running a chevy journal.  go with the 5.5...   Give up a little snap and get some umph
Go fast, don't turn
John Rayburn
« Reply #5 on: April 27, 2010, 06:31:04 am »
Stock weight car? Shortest rod you can get.
I also park at Nick's.
« Reply #6 on: April 27, 2010, 06:48:58 am »
If I had my way, I would have gotten my Ti Rods shorter than 5.5 for my 83 stroke. I'm running a full weight car. I totally agree with John. SHORT.
Ted
Jeff68
« Reply #7 on: April 27, 2010, 13:29:34 pm »
I also have Porsche length rods (Carillos) on an 82mm crank (2110 cc motor).  Works great..
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #8 on: April 27, 2010, 13:39:35 pm »
Some say it doesn't matter some say shorter is more torque or bottom end longer is more top end. I'm running 5.4 with FK10 and 86 stroke. 163 ft lb at wheels I say short.
airstuff
« Reply #9 on: April 27, 2010, 15:43:15 pm »
5.4 H-beams would be a great kick for street Wink
EL PINGO 66
« Reply #10 on: April 27, 2010, 15:58:14 pm »
thanks for all replys,,  and yes my car its full weight and i want runs 1/8 mile because here in mexicali the track is  short and we cant run 1/4 of mile....  Grin
RhoadsVW
« Reply #11 on: April 27, 2010, 20:25:27 pm »
Either the 5.352 or 5.400.  I ran the 5.500 and lost to much bottom end for the weight of the car and did not gain any top end for the amount lost of the bottom end.  Dave Rhoads
Der Renwagen Fuhrers
stealth67vw
« Reply #12 on: April 28, 2010, 03:16:40 am »
Another vote for 5.352 rods. I'm using a set of Eagles on a 78 stroke.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
EL PINGO 66
« Reply #13 on: April 28, 2010, 04:07:02 am »
oki doki... lets do it... 2276 w 5.352......
mushas gracias por sus respuestas ..
saludos  de mexicali mexico  ...
