September 22, 2026, 21:24:29 pm
| |-+  For sale!
| | |-+  very nice VDO Type 3 Tach
Author Topic: very nice VDO Type 3 Tach  (Read 3450 times)
Wünderwolff
aka Dr. Jeckill
« on: April 28, 2010, 20:03:28 pm »
Now that the Notch is as good as sold, I can as well try to get rid of this one. It is rarer than a hens teeth, I've read about crazy prices in the range of 600-800 dollars, so it won't come cheap, but make me a good offer and who knows.
I can take it to the DFL thingie-Mai-jingie this weekend.
It is in good condition, not tested but supposed to work (any one has a good trick to test a tacho?), has slight (very slight) pitting in the painted ring, chrome is good, nothing a good clean up can't fix.
Wünderwaffe are Go!
alex d
« Reply #1 on: April 29, 2010, 08:16:04 am »
what's the date stamped on the back¿ 6 or 12 volts?
Nostalgiavw67
« Reply #2 on: April 29, 2010, 20:52:50 pm »
I PM'd you  Wink
Jerome
Wünderwolff
aka Dr. Jeckill
« Reply #3 on: April 29, 2010, 21:16:58 pm »
I can't seem to find a date stamp, should it be in ink or rather stamped in like a chassis number would be. If the latter, there is a set of numbers near where the electric connectors are that says 7.70, but I would be surprised if the tach was made in 1970 as it definitely is the earlier style.
As for the voltage, it is both 6 as well as 12 Volt, depending on which connection you use. I do think it has been used in a 12 Volt car though as there is a 12 Volt light bulb in the thing.
I know Jerome (NostalgiaVW67) is very interested, he had already sent me a message yesterday, so it might well be off the market already. I'll update if sold.
Cheers,
Tim
Wünderwaffe are Go!
