September 24, 2026, 13:19:56 pm
| |-+  For sale!
| | |-+  ProTurbo fuel tank adapter
Author Topic: ProTurbo fuel tank adapter  (Read 2895 times)
m.m.p
« on: April 28, 2010, 20:49:12 pm »
ok, so this is the ProTurbo tank adapter im now selling Smiley
it has 4 X 3/8NTP outs, that ill allow from -6 to -10 Smiley so you can run two -10 out to your efi fuel pumps, a -8 return and a -6 to drain the fuel from your tank Smiley perfect
if you only want one out, just plug the ones your not using with NTP plugs
you can use the standard intank filter and washers Smiley
This it the highest flowing adapter out there, all the passages are as big as you can get from a stock vw tank Smiley
there £40 each
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
