September 24, 2026, 14:33:30 pm
| | |-+  Need some advise...
Author Topic: Need some advise...  (Read 6110 times)
dinsor2b
« on: April 29, 2010, 13:24:23 pm »
How to fit this steering wheel on 67US?
Look at gap between turn signal ring..gosh!
And how to remove a horn ring to turn a bolt on itl?
Please advise.
THANKS.
PS.Sorry for my English skill anyway.
« Reply #1 on: April 29, 2010, 13:30:24 pm »
You can loosen the the ''U" clamp under the dash and slide the steering column tube towards the wheel.
Then loosen the set screw on the turn signal switch and slide it towards the wheel a littel bit also.
Hopefully that will be enough to fill the gap.
« Reply #2 on: April 29, 2010, 13:36:38 pm »
Horn ring turns counter-clockwise.  They're usually tight, go slowly but firmly.
roland
lates are the new splits...
« Reply #3 on: April 29, 2010, 13:38:20 pm »
you should have a custom boss made...
dinsor2b
« Reply #4 on: April 29, 2010, 14:10:14 pm »
Thank you guy!
will update asps.
plasticblack
« Reply #5 on: April 29, 2010, 15:12:27 pm »
I don't think that wheel is going to sit happily against the indicator arm (amd look nice) without some kind of purpose made sleeve or collar being made to do the exact job.
Check out the collar from late 70's Golfs & Scirocco's and these are stepped and if cut/modified carefully could be a tidy solution to your problem.
dinsor2b
« Reply #6 on: June 09, 2010, 08:49:10 am »
Hello, from Thailand.
i just purchased this  Formula Vee Sporty.
And got the same question.....for you guys.
How to remove horn button or remove plastic collar off to turn a bolt on it?
i've google it but no answer and tried to remove horn contact screws but nothing can go far than that.
Hope you guys can figure it out.
Cheers!
« Reply #7 on: June 09, 2010, 13:57:22 pm »
Dinsor2b, very nice steering wheel. What year car are you putting that on? Those wheels are intended for the later produced cars. But they might be able to be used on earlier cars with some modifications. Sorry that I can't offer up any advice... I have the earlier Formula Vee wheel for my '67.
dinsor2b
« Reply #8 on: June 11, 2010, 19:00:39 pm »
i've got the answer. it's very easy..... Grin
thank you everyone.
dinsor2b
« Reply #9 on: June 12, 2010, 17:40:55 pm »
Maybe it's gonna sit in my 67 soon?
What do you think?? Wink
