October 15, 2026, 07:34:49 am
| | |-+  What do you use to clean terminals at the fuse block and headlight switch?
Author Topic: What do you use to clean terminals at the fuse block and headlight switch?  (Read 5209 times)
Brandon Sinclair
« on: May 07, 2010, 07:56:50 am »
I have an original harness and if you look at the terminals on the wires they look kind of corroded and could use a cleaning if not a new connector.  What do you use to clean the terminals and male connectors-sandpaper, rubbing alcohol, a fiberglass brush or brass brush, or maybe electronic spray contact cleaner or something else?  Also if I need to replace some wire ends is there some kind I should be looking for in the stores that are the best to use besides the tin ones available everywhere?   I have been dreading doing this job but I am going to take a few hours and clean up the spaghetti wiring and zip tie eveything nice and neat.  Thanks.
gizago
« Reply #1 on: May 07, 2010, 09:41:11 am »
I usually use a 1200 grade wet'n dry paper.
Rasser
« Reply #2 on: May 07, 2010, 11:36:16 am »
small brass brush, then followed by "battery terminal grease"
1955 type1
1966 type2 13w deluxe
Kaferdog
« Reply #3 on: May 07, 2010, 15:33:38 pm »
I used my Dremel tool with a stainless steel wire wheel ...looks brand new ...it was fast and painless... Grin
« Reply #4 on: May 07, 2010, 15:53:33 pm »
Ultrasonic cleaner for the fuseblock, soap and a brush for the headlight switch, and the correct metal terminals can be purchased from Wurth.
I believe Wurth has an online catalog. Otherwise, I know you guys have killer hardware and electrical supply houses out there ... Mcfadindale Hardware? That place is the BOMB. Wink
Brandon Sinclair
« Reply #5 on: May 07, 2010, 18:22:35 pm »
Tom,
What cleaning solution mix did you use in your ultrasonic cleaner for the fuse block?  Thanks.
« Reply #6 on: May 07, 2010, 20:08:54 pm »
Hey Brandon ...
I just use the general purpose cleaner for these types of things or the mc-1 cleaner works well to. Actually, the GP cleaner is harder on aluminum that the MC-1!
Those cleaners are fantastic. Just slip your hand in there when its a little warm ... pretty freaky feeling ... almost electric. Excellent for carbs, pistons, rods too ... that's what I got it for.
Good to meet you.
Take care,
TxT
kingsburgphil
« Reply #7 on: May 08, 2010, 03:26:35 am »
I concur with Tom, try Wurth products Contact SW and Contact OL. They work very well where mechanical means are inappropriate (late model cars with multi pin
connectors).
Also Wurth Cockpit Cleaner works nicely on new car dashboards....(it's not some spray silicone crap)
In fact I've been happy with every Wurth product or tool I ever used.  Wink
