November 02, 2026, 21:35:27 pm
| | |-+  Cam question
Author Topic: Cam question  (Read 19972 times)
Sander/DVK
« on: February 25, 2007, 17:42:59 pm »
Hi, a friend of my has a 1955cc.
The specs are:
90,5x76
041 heads with 40x35,5
44 DCNF with 34mm vents
CR is unknown yet, and a Scat C25 cam.
1:1,25 ratio rockers
The heads are off the engine, and we concluded that the CR are too low (1:6,4), so that would be changed, dependent to wich cam we gonna use
Now, the cam is a Scat C25 and that is too mild I think.
Wich cam would you guys use on this engine?
« Last Edit: February 25, 2007, 18:19:48 pm by Sander/DVK » Logged
« Reply #1 on: February 25, 2007, 18:35:51 pm »
Engle 120, 9:1 compression.
Sander/DVK
« Reply #2 on: February 25, 2007, 18:41:49 pm »
Thanks Zach, but is the W-serie from Engle not a little bit "too old"?
Why not a cam from the VZ or the FK series?
« Reply #3 on: February 26, 2007, 02:18:36 am »
VZ cams are hard on lifter bores and they can't be used with your 1.25:1 rockers. FK cams require an upgrade to 1.4:1 rockers for best performance. So the most inexpensive way to upgrade using the parts your friend has, is using the 120 cam with your 1.25:1 rockers. Combined with the increased compression, he will notice a HUGE power increase over the little C25 in there now. If the heads are ported properly, the engine will make great torque and horsepower up to 7,000 rpm. Hows that for an "old" cam?? Wink
« Last Edit: February 26, 2007, 02:20:26 am by Zach Gomulka » Logged
cedorUSA
« Reply #4 on: February 26, 2007, 04:13:39 am »
i run angle 110 with 1.4 and make over 2oo hopwer with 87m 69m witch is 1835 (yes) its all in the heads and its all good
all about heads and cariboraetors sometimes only idas will do
« Reply #5 on: February 26, 2007, 06:21:18 am »
Sure you do.
Why dont you go waste bandwith on a Honda forum? Theres lots of people there, just like you.
Sander/DVK
« Reply #6 on: February 26, 2007, 19:23:11 pm »
Thanks Zack, thats very interesting information!
"Old cam" is not the good word, but I think you know what I mean Wink
The C25 is about the same as a W100, and thats crazy for a 1955 Huh
Thanks again,
Sander
Sander/DVK
« Reply #7 on: February 26, 2007, 19:25:27 pm »
Shocked Are you sure?? Thats a lot HP for such engine!!
69x87 = 1641cc btw Wink
Cheesepanzer
« Reply #8 on: February 28, 2007, 03:10:11 am »
200hp from an 87 METER x 69 METER engine shouldn't be too much to ask for!!!!  Grin
But how the heck he fits it (or his big head) in his car is beyond me.
Jim, there's no substitution for displacement, right? Cheesy
63 Type 2 Single Cab
Cornpanzers
cedorUSA
« Reply #9 on: February 28, 2007, 04:53:40 am »
im goin by my naybors man, they said its 1835 maybe i made a misteak,
