November 02, 2026, 19:55:35 pm
| | |-+  Mallory Hyfire 6 question
Author Topic: Mallory Hyfire 6 question  (Read 6276 times)
Flenne
« on: May 14, 2010, 18:52:38 pm »
I have a problem with my ignition.
A few years ago, I bought a complete setup from Mallory. Unilite distributor, Hy fire 6AL Control and a promaster Coil.
There has always been an ignition failure, like a missing signal. Its worst when its cold??
The problem is solved when I bypass the system, so the control box is not in use.
Checked if any wires are damaged, but seems to be ok.
Would like to hear if any of you, have had this problem, and what to do if it is so. Huh
Have a thought of trying a Mallory Active Power Filter? Or maybe the Breakerless module in the distributor is damaged??
Flenne
« Last Edit: May 15, 2010, 12:47:59 pm by Flenne » Logged
Member of the JohnDoeVeeDubs.blogspot.com
69Stu
« Reply #1 on: May 14, 2010, 22:17:40 pm »
I had a similar problem, with a high RPM miss fire. When I bypassed the Hy Fire control box the problem went away. I replaced the Hy fire box with another, same problem.
I tryed rerouting the cables, seperating them and even shielding them, with no improvement.  Cry
I ended up changing it for an MSD Digital 6, and have had no problems since.
Flenne
« Reply #2 on: May 15, 2010, 08:20:13 am »
Thanks 69Stu
 Shocked Expensive solution, but might be it then...
Regards Flenne
« Reply #3 on: May 15, 2010, 11:33:50 am »
Hello.
Normally its because the trigger wire and the supply wire are too close. If thatīs not the problem I have no answer to it. I have long forgotten what you have Flenne. But shielded ignition cables is a must Bad cables can create exactly what you describe.
jamiep_jamiep
« Reply #4 on: May 17, 2010, 13:36:54 pm »
Do you have the earth direct to the battery?
Flenne
« Reply #5 on: May 17, 2010, 14:19:16 pm »
Hi.
No, its grounded in the pan.
Regards
Flenne
« Reply #6 on: August 02, 2010, 15:35:48 pm »
 Lips Sealed
Problem solved...
The Coil apparently did the misfiring after all..
After several different checks, different wiring with ground/earth, sealing the wires etc, I tried to change the coil.
An old Bosch did the work fine... Now the mighty fine Mallory is goin on the shelf of shame..
But thanks for all the help anyway guys. Wink
