October 13, 2026, 08:14:24 am
| | |-+  Sequential Gearbox?
Author Topic: Sequential Gearbox?  (Read 15576 times)
Basti
« on: May 18, 2010, 12:25:24 pm »
Hey Guys!
Did anybody try a sequential gearbox in a beetle?
Which one would you use?
I´m thinking about a Hewland MK9 but like to know your opinions...
Cheers,
Basti
- black 62 cal look beetle
- Pro Mod Race car
Turbo_Rich
« Reply #1 on: May 18, 2010, 15:27:38 pm »
That would be a dream mmmm Wink Only person I know that runs a sequential box is this guy http://www.rojoracing.nl/car.html But it looks like a lot of home brewed engineering on it  Shocked
Basti
« Reply #2 on: May 18, 2010, 16:49:12 pm »
the gearbox looks not so bad, but there is the wrong engine mounted Wink
Thanks for the link, i dropped him an email....
- Pro Mod Race car
Martin
Cash Converter....
« Reply #3 on: May 19, 2010, 10:18:33 am »
the hewland M9 box isnt up to to the job, spoken to them about it. Would be ok on a N/A motor but turbo..... kaboooom! lol
best on ive found so far is the Albins unit, if you have a spaire $20,000 Aus dollor!
Martin
www.taylormachine.co.uk
OFF/500
« Reply #4 on: May 19, 2010, 10:47:02 am »
How about using a vertigate shifter set-up powered by CO2? Have the gearshift fired by the shift light!
Basti
« Reply #5 on: May 19, 2010, 14:09:01 pm »
@Martin: the MK 9 should be good for 220nm..that´s all ;(
  Do you have any other systems??
@Neil: how about a sequential gearbox which shifts automaticly at the revs you want? Wink
- Pro Mod Race car
Dominick Luppino
« Reply #6 on: May 19, 2010, 17:00:20 pm »
Here is one that will work, they run LS1 Chevy behind it also has a Bell Housing for the VW. Looks like a Mendy and is sold at Rancho Performance Transmissions.
http://www.pbseng.com/pqs4_outline.htm
« Reply #7 on: May 19, 2010, 17:21:07 pm »
Thats what I thought, connect the shift light to a couple of wires so as soon as the light comes on you get an output signal. I suppose an MSD rpm-operated switch would do the same job... The signal could tell a CO2 cylinder to shove the shiftrod into the gearbox, and each time the light came on it would change up a gear. The trick would be to get the shift working properly - I think you'd need a three-position cylinder to go from 1st through neutral into second, then the shift from second to third would require pulling the first shiftrod out of 2nd into neutral while banging the next shiftrod from neutral into third. I suggested the vertigate because I know that has seperate input rods but I don't know what cleverness goes on inside the nosecone!
Martin
Cash Converter....
« Reply #8 on: May 19, 2010, 17:24:18 pm »
Yeah spoken to them too!
I have got a design for a sequential shifter ready to produce, Im going to be testing it in my car at the end of the year.
 as for a sequential box, thats just in the CAD. there will be a T1 version as well as a T2. so you can swop out your old gear set and pop in a new one! (well peter can;) )
Martin
Martin
OFF/500
JIMP
« Reply #9 on: May 19, 2010, 19:42:01 pm »
Hello
I remember of a german company with a website called "secrets of speed" which used to advertise sequential gearboxes for beetles, this was some 3 years ago and I can't find it any more, does anyone has any info on that one?
Friendly
Dimitrios
red baron
« Reply #10 on: May 20, 2010, 09:45:06 am »
There are some austrian guys using a sequential gearbox for hillclimbs and slalom races.
http://www.vw1303.at/bilder/projekt_06/7.htm
this is the gearbox - if u want to see more of this car just click "startseite" and then technik or also very interesting 2ohc  Tongue
cheers
Basti
« Reply #11 on: May 20, 2010, 19:59:36 pm »
I talked to the guys of www.fastspeed.nl
They are converting 930s gearboxes, which doesn´t sound so bad.
The american version isn´t a cheap deal...but looks very sweet.
Did anybody bought one of these?
- Pro Mod Race car
Felix/DFL
« Reply #12 on: May 22, 2010, 11:30:44 am »
Hey Basti,
maybe you should spent some time behind the wheel of your car & on the track before changing Wink
DFL 402@Bitbug ?
Greetz,
Felix
Basti
« Reply #13 on: May 22, 2010, 16:38:16 pm »
Hey Felix!
Dreams are one thing, driving another...Wink
But i looks like I will be at Bitburg.
I need to improve the times of the black one...
Cheers,
Basti
- Pro Mod Race car
