September 21, 2026, 01:20:54 am
Latest Member: Bad Habit
| | |-+  Zf Diff installation
Author Topic: Zf Diff installation  (Read 11387 times)
Rocket Ron
It's old school for a reason
« on: May 19, 2010, 10:58:36 am »
After a few dead ends and after buying a box that was supposed to have a ZF diff in I managed to pick up a zf diff over the winter and am hoping to install it this weekend.
Are there any ZF specific installation procedures I should be carring out or is it pretty much the same as the super dif install.
Thanks in advance
Ron
13.12 @ 101.84
Grooving out on life
181
« Reply #1 on: May 19, 2010, 12:32:02 pm »
I´m interested in this as well. Any mods for oiling needed?
« Reply #2 on: May 19, 2010, 14:05:55 pm »
IRS?
Swing axle?
Rocket Ron
« Reply #3 on: May 19, 2010, 14:17:23 pm »
swing axle
13.12 @ 101.84
Felix/DFL
« Reply #4 on: May 19, 2010, 21:22:59 pm »
Hi Ron,
I got some very good and helpfull advices from bruce about drill the diff housing to get more oil to the discs.
And I modified both side plates at the gearbox with the oilholes as shown in the vw manual.
Greetz!
jr59
« Reply #5 on: May 19, 2010, 21:30:50 pm »
following ths pots,
I would like to know if we can purchase new disc for ZF.And by the way where Wink
We got one waiting in the garage with worn disc so...
the photo are very helpfull
cheer
JR
Rocket Ron
« Reply #6 on: May 19, 2010, 21:33:56 pm »
Hi Ron,
I got some very good and helpfull advices from Bruce about drill the diff housing to get more oil to the discs.
Greetz!
Hi Felix
that's some big holes you've drilled there, what sort of size are they Huh
also the extra holes in the side plates is that both sides . They appear to be above where the axle boot locates is that right ??
sorry for all the question
regards Ron
13.12 @ 101.84
Felix/DFL
« Reply #7 on: May 21, 2010, 12:05:29 pm »
Hi Ron,
the holes are 12mm and extended them to oval and angeled them to grab up the oil like the existing middle holes.
I modified both sidecovers with openings directed to the backside.
I am not 100% sure about the function of the extra oppenings.
As I understand throw around oil should drop thru the top hole to the cone section and then to the bearing?
As VW advcived it for LSD I did it as shown.
Don´t forget to cut a little piece off the plastic cone spacer (between axlehousing - sidecover)
I even secured the plasic thing with sealer so it can`t be turned.
Have fun,
Felix
Rocket Ron
« Reply #8 on: May 21, 2010, 15:45:57 pm »
Thanks for the info felix
I take it that you also pre lube before putting everything back together
Thanks again
Ron
13.12 @ 101.84
Felix/DFL
« Reply #9 on: May 22, 2010, 11:07:54 am »
Hi Ron,
pre lubing especially at the discs is essential.
For the gearbox I use Shell Spirax GL5 LS oil
Cheers,
Felix
« Reply #10 on: June 17, 2010, 11:09:15 am »
hey guys,
can I use differential oil or is it too viscous?
I found this in a local shop:
CASTROL SAF XA, but castrol says it can lead to reduced synchronizer performance
« Reply #11 on: June 18, 2010, 16:21:06 pm »
called castrol today,
and they said use SAF XJ, its used for BMW LSDs and should work
