October 25, 2026, 14:25:01 pm
352327 Posts in 28959 Topics by 6929 Members
Latest Member: Hanibal1
| | |-+  Few engine building questions: torque specs for various parts, etc.
Author Topic: Few engine building questions: torque specs for various parts, etc.  (Read 6250 times)
bugnut68
« on: May 20, 2010, 03:16:31 am »
A few miscellaneous questions:  what do you torque the end bolts to solid rocker shafts to?
What is the necessary/proper way to set up sufficient breather system for a 2017... do I do both valve covers, or just the 1/2 side, plus the outlet on the oil filler?  What's needed?
To what capacity is the stock fuel pump sufficient?  What's the maximum it can handle?
What do you all seal your sumps with?  I've heard stock oil change kit gasket, along with other sealants... just curious.  Also, what do you torque the fasteners to?
What is the preferred main seal to use, red or black?  I have an Elring kit with the red gasket, just wondering if that's sufficient?
Speed-Randy
« Reply #1 on: May 20, 2010, 03:29:46 am »
Just torque every thing to 90 foot pounds, cant go wrong there Grin Grin Grin. just kidding, all that info is on the samba technical section or the idiot book, other manuals as well
bugnut68
« Reply #2 on: May 20, 2010, 16:47:59 pm »
Lol, it's been seven years since I built my 1776, and I can't remember what I torqued the solid shaft end bolts too... darn my poor memory.  Grin
bugnut68
« Reply #3 on: May 21, 2010, 17:09:10 pm »
Checked the Samba tech section, found nothing about proper torque for solid rocker shafts, or any of the other stuff.  Anybody have any ideas?
« Reply #4 on: May 21, 2010, 17:10:47 pm »
I usually torque mine the same as the 8mm bolts and studs.  18ft lbs.
bugnut68
« Reply #5 on: May 21, 2010, 17:28:19 pm »
Thanks Don!
« Reply #6 on: May 21, 2010, 18:44:01 pm »
do you put the shafts in a bench-vise when torquing those bolts? since they're round you see... Grin
« Reply #7 on: May 21, 2010, 18:52:13 pm »
I put an 8mm stud in my vise and lock it down tight then put the shaft over the stud and torque the ends.  You have to set everything up first then ensure you put it on the correct head of course.
bugnut68
« Reply #8 on: May 23, 2010, 01:23:21 am »
Any further insight on the other questions, anyone? Extent of breather needs, capacity of stock mechanical fuel pump, which main seal to use?
neil68
« Reply #9 on: May 23, 2010, 06:52:37 am »
I'm still running stock fuel lines and pump with IDA's...12.9 seconds at 104 MPH.
I use the Elring orange main seal installed all the way into the case.
When my engine was still a 2017 cc running 14's, I got by with a breather tower (Latest Rage "Porsche" style).  However, when I upgraded to 2332 cc and 7,000+ rpm, then I had to add a CSP box.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
