September 22, 2026, 21:24:28 pm
Scat ARP rod bolts torque setting
Topic: Scat ARP rod bolts torque setting (Read 7718 times)
Rocket Ron
It's old school for a reason
May 20, 2010, 10:15:31 am »
Could someone confirm the torque settings and stretch for Scat 3/8 ARP rod bolts
thanks in advance
Regards Ron
13.12 @ 101.84
Grooving out on life
flatfire
Re: Scat ARP rod bolts torque setting
May 20, 2010, 14:17:54 pm »
This what I did make sure you use the lube and work the rod bolt a several times in and out of the rod.
Its a good video IMHO thanks AJ
http://www.lowbugget.com/rodboltvideolink.html
Rocket Ron
May 20, 2010, 14:35:58 pm »
thanks for that
I'll have to watch it at home as I've no sound on my computer at work
13.12 @ 101.84
besserwisser
May 20, 2010, 17:28:58 pm »
You have all the tourque settings on Scats homepage.
Rocket Ron
May 21, 2010, 15:47:39 pm »
I looked on there the other day and couldnt see it but checking again last night they are there
Don't know where i was loooking
regards Ron
13.12 @ 101.84
Bernard Newbury
9.50 @ 141 MPH
May 21, 2010, 16:07:00 pm »
Quote from: ROCKET RON on May 21, 2010, 15:47:39 pm
regards Ron
This link might help >
http://www.arp-bolts.com/Tech/TechTorque.html
Bernie
Jøran Larssen
May 21, 2010, 20:13:31 pm »
Quote from: ROCKET RON on May 20, 2010, 10:15:31 am
thanks in advance
Regards Ron
The torque for my Scat 3/8 rod-bolts is 42 ft/lbs (H-beam rods).
Last Edit: May 21, 2010, 20:15:18 pm by Jøran Larssen
SCC 2010: 11.103 @ 192.00 km/h
flatfire
May 22, 2010, 11:15:20 am »
On the video it stated 41ftlbs i tried it in conjunction with the .0055 stretch on my wrench it needed 42 ft lbs.
Rocket Ron
May 22, 2010, 21:09:03 pm »
thanks for the info guys
Regards Ron
13.12 @ 101.84
