September 26, 2026, 16:32:36 pm
| |-+  For sale!
| | |-+  marco mansi's special IRS bolts now ready!!!!!!!!!!!!!!!!!!!
Author Topic: marco mansi's special IRS bolts now ready!!!!!!!!!!!!!!!!!!!  (Read 7784 times)
m.m.p
« on: May 21, 2010, 00:22:16 am »
hi all, i have 8 pairs of irs bolt ready, i know its been a long wait but there here Smiley, there made of 304 stainless and are a new design with no wealding, i recommend you use the red bugpack rubbers.
they are £100 plus postage a pair payable to marcomansi@aol.com via paypal
thanks marco mansi.....
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
m.m.p
« Reply #1 on: May 22, 2010, 14:57:36 pm »
if anybody is intrested in these, send me a P.M asap, as there almost gone already Sad
Marco Mansi
0044(0)7947 660 924
« Reply #2 on: May 22, 2010, 23:26:51 pm »
excuse my ignorance, perhaps due to me being a swinge axle "driver"
but what's the "special" factor here...
adjustability of the IRS arms?
m.m.p
« Reply #3 on: May 23, 2010, 16:23:50 pm »
yes!!   this allows adjustability to the inner irs mount(near the gearbox) which is not usually adjustable Smiley
Marco Mansi
0044(0)7947 660 924
Tomi
« Reply #4 on: June 12, 2010, 06:53:02 am »
Thanks for the bolts, Marco! I installed them and they really do work. I bet there's no need for swapping trailing arms on lowered IRS cars from side to side to get the wheels straight, these bolts will do the trick. How many degrees is the total camber adjustment with these bolts?
Brap Brap Brap
« Reply #5 on: June 12, 2010, 07:58:17 am »
Hello
I'm interessted but don't understand the work of the bolts and the installation.
Simply change from original to your bolt? And then you can adjust the camber?
I adjust the camber with an excenter bolt on the springplate. Is this the same ?
Dirk
max, Der Bahnstormerz
« Reply #6 on: June 16, 2010, 16:56:31 pm »
I'll have a set but you'll need to get your ass back to London and give my rear end a good seeing to
« Reply #7 on: June 16, 2010, 23:31:47 pm »
how do i delete a message?
« Reply #8 on: June 17, 2010, 12:41:54 pm »
Any left? All gone?
