October 14, 2026, 21:47:14 pm
duel zenith vergaser kit
Topic: duel zenith vergaser kit (Read 5970 times)
pitparts
February 27, 2007, 00:46:07 am »
i'm looking for information on useing duel zenith carb on my 1300 dp in 1970 type 1. do the carbs need vaccum line to distributor?
cheers
pitparts
simon uk
Re: duel zenith vergaser kit
February 27, 2007, 10:15:52 am »
I am not sure there is a vacuum line out of a zenith, it probably be better to use a bosch 010 distributor or something if you are using twin carbs. Is the kit set up for a 1300, seems it might be over-carbed?
Si.
Gregor/DFL
No comment...
March 02, 2007, 13:54:00 pm »
HI!
The Zenith 32 NDIX carbs do not have a vacuum line. Itīs also depending on the manofolds-itīs possible to adapt a vacuum line but it will be much better to use a 010 or 009 distributor. The Zenith crabs sometimes have the problem of having "micro cracks" in their bodies, so it can be a problem to synchronize/adjust them properly. Itīs also not the easiest thing to get spare parts or differnet jets for the carbs...After bad expierneces with those carbs, I kicked them out and mounted Weber 40 idf-much more relieable carbs. The Weber 36 idf should match your 1300 engine much better than 40 idf or 32 NDIX!
1965 black bug with Empi 5s
