September 14, 2026, 05:30:19 am
352306 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  Dim. of CB rocker shafts
Author Topic: Dim. of CB rocker shafts  (Read 4502 times)
« on: May 24, 2010, 02:29:40 am »
Anybody know what dim. are the CB ratio rocker shafts? Thanks in advance!
Ted
stealth67vw
« Reply #1 on: May 24, 2010, 03:28:43 am »
CB claims .984" but I would guess that is the center section. I would have to pull my rockers apart to measure for you.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
181
« Reply #2 on: May 25, 2010, 14:52:14 pm »
I can measure my spare shims if it is good enough for you
Unkl Ian
« Reply #3 on: June 08, 2010, 19:03:57 pm »
That would be 20mm dia.
« Last Edit: June 19, 2010, 17:52:51 pm by Unkl Ian » Logged
« Reply #4 on: June 08, 2010, 21:02:04 pm »
I measured it, it's .764, similar to Berg's, I ended up using some of the .015 Berg shims to fix the end play. Thanks guy's Good info to have, just in case.
Ted
