September 24, 2026, 14:20:08 pm
| |-+  For sale!
| | |-+  Turbos, Turbos and more Turbos!!!!!!!!!!!!!!!!!!!!!!
Author Topic: Turbos, Turbos and more Turbos!!!!!!!!!!!!!!!!!!!!!!  (Read 5353 times)
m.m.p
« on: May 25, 2010, 21:06:51 pm »
After having great success with Matt Keens motor using a Holset turbo, i have made some inquires and have come up with a line of holset based turbos that will spool faster and make more power than there Garrett, Turbonetics versions, also being much much stronger and durable, but the best part is the price!! they are half the price of there nearest competitor  Grin
i have 3 versions available
Hx30........ Capable of 3bar boost and 500bhp, ultra fast spooling, external wastegate, MWE (Map Width Enhancement) ported shroud inlet, high efficiency 6 blade compressor wheel featuring extended tip technology, T3 turbine flange, 9cm(.52 a/r) divided split pulse turbine housing. Suitable for 1641cc and over engines wanting 200bhp+ and especially suitable for fast spooling bus and bug daily driver, this turbo will spool quicker than the S2A Schwitzer(CB performance turbo) but is capable of over 400hp!!!(more power than the TO4B35!!!!)))))
price 500 pounds!!
Hx35........Capable of 3bar boost and 600bhp, ultra fast spooling (i have seen 20+ psi by 3500rpm on a 1914cc!!!!!), external wastegate, MWE (Map Width Enhancement) ported shroud compressor inlet, ultra-high efficiency 7 blade compressor wheel featuring extended tip technology, T3 turbine flange, 12cm(.70 a/r) divided split pulse turbine housing. Suitable for 1914cc and over engines wanting 300bhp+ for larger power street eater, strip motors.
price 550 pounds!!
Hx40........Capable of 3bar boost and 700bhp, ultra fast spooling (similar speed to the 500bhp Garrett GT30R! but equivalent power of the GT4088R! ), external wastegate, MWE (Map Width Enhancement) ported shroud compressor inlet, ultra-high efficiency 7 blade compressor wheel featuring extended tip technology, T3 turbine flange, 14cm(.86 a/r) divided split pulse turbine housing. Suitable for 2110cc and over engines wanting 400bhp+ for drag racing up to 700bhp!!!
price 600 pounds!!
there will be a 6 month NO QUIBBLE warranty even if its used for drag racing!!!!!!
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
Rocket Ron
It's old school for a reason
« Reply #1 on: May 25, 2010, 21:42:19 pm »
that some good prices !!!!!
13.12 @ 101.84
Grooving out on life
m.m.p
« Reply #2 on: June 01, 2010, 22:44:56 pm »
thanks mate, when you go to the dark side give me a call Wink
Marco Mansi
0044(0)7947 660 924
Rocket Ron
« Reply #3 on: June 02, 2010, 07:46:22 am »
unfortunately I've just had my turbo rebuilt at a cost of £350.
It is roughly the same spec as you Hx35 so would have been worth the little bit extra to get a new one. Turbo dynamics price for a new one of the same spec was the best part of £1200 Shocked
ps TTT
13.12 @ 101.84
bang
« Reply #4 on: June 02, 2010, 14:37:26 pm »
are they with carbon seal? so they can be used for draw true setup?
m.m.p
« Reply #5 on: June 02, 2010, 15:10:28 pm »
hi Bang, no not yet, but im working on it, as many people want them with a carbon seal. Sad
Marco Mansi
0044(0)7947 660 924
