August 12, 2026, 23:39:29 pm
Questions on installing cloth headliners
Topic: Questions on installing cloth headliners (Read 4509 times)
May 26, 2010, 00:47:41 am »
I have never have used a cloth headliner before, Whats the does and dont's. Thanks
Re: Questions on installing cloth headliners
May 26, 2010, 01:11:22 am »
Paging Mr. Zach Gomulka... Mr. Gomulka to the white phone
May 26, 2010, 01:36:09 am »
¡No habla ingles!
Ok, ok. I'm assuming you've done vinyl headliners before? It's not much different. Cloth is a little less forgiving than vinyl, you've got to make sure it's pulled right. DON'T use a heat gun on cloth, steam it instead. That's about it.
May 26, 2010, 01:58:56 am »
Thanks zack, I have done a few vinyl ones before. I threw them in the dryer first to slighty heat them up first. Now on the steam method, Squirt bottle with water and a electric iron on low work ?
T.Fabs
May 26, 2010, 02:16:55 am »
Hi Danny,
Ask Lenny at WCCR. He will help you for sure!
Proud Member of the Der Kleiner Panzers.
rick m
May 26, 2010, 02:58:20 am »
Danny,
In the mid 90's I jumped on the tweed band wagon and put a gray tweed headliner in my 67 (not personally but had it done). It was a bugger (no pun intended) when cutting in around the rear and quarter windows. It was a little thicker making the mounting of the rear and quarter windows a challenge to get the rubber seated in all the way. Where some of the seams in the headliner (at the pillars) met the quarter windows, we had to use a little extra contact cement and lay down the seam with only half the fold going under the rubber.
Besides the windows, the rest went in like a regular headliner...and definitely use a good steamer. I watched my go in and have an appreciation for anyone who does them.
Rick M
Rick Mortensen
Driving Hot VWs since 1970
May 26, 2010, 03:16:17 am »
We use a Jiffy Steamer, I've never tried an iron and a squirt bottle, but it might work(?)
Tweed is easier than normal cloth because it stretches a LOT more.
Rick, your door panels are done
May 26, 2010, 04:16:07 am »
Are you doing a one piece headliner or an original style multi piece?
